fjr
new installed raspbian from noobs v. 3.2.1 on rp 0 sudo apt-get update displays error
Sat Jan 25, 2020 7:27 pm
raspberry pi zero
raspbian installed from noobs v. 3.2.1
Raspberry pi zero connected to internet by usb ethernet.
sudo apt-get update and
sudo apt-get upgrade
displays message
$ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
vlc-bin : Depends: libvlc-bin (= 3.0.8-0+deb10u1+rpt1) but 3.0.8-0+deb10u1+rpt7 is to be installed
vlc-plugin-skins2 : Depends: vlc-plugin-qt (= 3.0.8-0+deb10u1+rpt7) but 3.0.8-0+deb10u1+rpt1 is to be installed
E: Broken packages
How can I upgrade?
Thank you.
alphanumeric
Re: new installed raspbian from noobs v. 3.2.1 on rp 0 sudo apt-get update displays error
Sat Jan 25, 2020 8:22 pm
Try apt instead of apt-get, sudo apt update, sudo apt upgrade.
Sat Jan 25, 2020 8:50 pm
Probably an out of sync mirror or one in the middle of an update. I think someone else reported a similar issue recently.
Try the update and upgrade again later.
It won't make any difference in this case (or most cases) if you use apt or apt-get.
Unreadable squiggle
ShiftPlusOne
Sat Jan 25, 2020 8:54 pm
iirc, 'upgrade' will refuse to remove packages, but this particular update will want to replace some. full-upgrade or dist-upgrade should handle it.
Sat Jan 25, 2020 9:01 pm
True, but 'upgrade' won't try to handle any packages that need new packages installed or old ones removed. It will just show them as "x packages not upgraded" instead of spitting out errors.
Unreadable squiggle
ShiftPlusOne
Sat Jan 25, 2020 9:12 pm
Then I think I'd need to get an old image and try the 'upgrade' method to figure out exactly what it's complaining about, because quite a few people are having trouble with this one.
I am 80% sure that the recommended approach of 'sudo apt update && sudo apt full-upgrade' will resolve it though.
Sat Jan 25, 2020 10:22 pm
I'll have a go myself too, when I get time. Too busy tomorrow, off to a spider show in Kent. We will be bringing one home with us :)
Unreadable squiggle
fjr
Sun Jan 26, 2020 9:32 am
I ran
sudo apt update
sudo apt dist-upgrade
sudo apt update
sudo apt upgrade
sudo apt-get update
All commands displayed
0 upgrated
0 newly installed
0 not upgraded
Can it be right, that there are no updates for
a new installed system?
Can this error stay on for hours?
Sun Jan 26, 2020 10:23 am
I just installed a fresh Full Raspbian system from the latest image, ran sudo apt-get update and sudo apt-get upgrade and it has all gone well.
Could you post the output of 'apt policy' and 'apt-policy vlc-bin' to see if they give us any clues.
If there have been no updates since the image the system uses was built, yes, but that isn't likely, and almost certainly not in this case.
Sometimes. It seems a few others have had the same problem, so I suspect one of the mirrors has got some corruption somehow.
Unreadable squiggle
fjr
Sun Jan 26, 2020 5:00 pm
current release is Buster
It was a mistake.
Another sd card was inserted.
ShiftPlusOne
Sun Jan 26, 2020 5:33 pm
Stretch? The current release is Buster.
Sun Jan 26, 2020 6:24 pm
Running Stretch is definitely not a good idea. You should really be running Buster as ShiftPlusOne said.
However, I'm still puzzled as to where the version 3.0.8-0+deb10u1+rpt7 of libvlc-bin and vlc-plugin-qt is being picked up from. Stretch should be looking for version 3.0.8-0+deb9u1+rpt1 of those packages.
It sounds like you have a "FrankenRelease" with a mix of Stretch and Buster, but that isn't showing in your apt policy output which seems to be pure Stretch.
Could you try the update/upgrade again, verify it still comes up with those messages (just to be sure all the sources are set up correctly) and then post the output of 'apt policy libvlc-bin vlc-plugin-qt'. Hopefully that will throw some light on where these package versions are coming from.
I have tried a test on a Raspbian Stretch system, and it uses the 3.0.8-0+deb9u1+rpt1 for all of those files.
Unreadable squiggle
fjr
Tue Jan 28, 2020 3:53 pm
No my opening post was correct. It is raspbian installed
from noobs 3.2.1.
Then I had switched the sd card and that sd card had
a previous version of raspbian installed. Therefore
the wrong posting later on.
Now I got the right sd card, raspbian from noobs 3.2.1, mounted
and ran
sudo apt update
sud apt upgrade
It worked. Those commands also worked on a sd card,
I installed raspbian buster with desktop image
on.
Tue Jan 28, 2020 4:23 pm
from noobs 3.2.1.
and ran
sudo apt update
sud apt upgrade
on.
https://www.raspberrypi.org/documentati ... pdating.md
Thinking outside the box is better than burying your head in the sand...
