FreeWm
Pi4 how do we install apps on external drive
Thu Jan 23, 2020 12:54 pm
Since SD card has limited space, app has no room for data.
So I have a 500Gb drive but how to install app on drive?
Also, how do we get external drive to show up in File Manager when opened?
Could not find in docs or on board.
Any help is much appreciated.
swampdog
Re: Pi4 how do we install apps on external drive
Thu Jan 23, 2020 3:13 pm
Is the 500Gb drive going to be *permanently* attached?
protosam
Thu Jan 23, 2020 3:18 pm
It's bad practice to install apps on external devices in Linux. I see it being very infeasible to exceed 32 GB on just installed programs alone unless you're just trying to bork things on purpose.
Use external drives as "data" bearing disks only. If you're finding that /home/USER stuff is taking up a lot of data, move the user onto an external data disk or just give the user perms on a directory on the data disk.
Anyways, just don't try installing things from your package management (apt) onto an external drives, there's just too many problems you're going to run into.
Thu Jan 23, 2020 3:31 pm
Apps are generally associated with Android.
Debian uses Software Packages.
It can be difficult to split software packages between drives because of dependencies.
Retired disgracefully.....
......to a more gentile life !
gkreidl
Thu Jan 23, 2020 4:38 pm
Move the root filesystem to the USB drive ...
Minimal Kiosk Browser (kweb)
FreeWm
Fri Jan 24, 2020 3:33 am
Yes, in this instance the drive will be permanently attached.
Surely we have to tell the system where the root file system is. Where would I find this in the docs?
RonR
Fri Jan 24, 2020 4:23 am
Running Raspbian from USB Devices : Made Easy
gkreidl
Fri Jan 24, 2020 4:39 am
If you want to do this yourself, here's a great tutorial: https://www.raspberrypi.org/forums/view ... 29&t=44177
FreeWm
Fri Jan 24, 2020 5:03 am
Alright!
Running Raspbian on USB Devices : Made Easy
Seems within my grasp, will try it first chance I get.
Also looks promising ... will have to study tho.
Thanks a bunch y'all, really appreciated.
