RDK
No wifi connection with Raspbian-Buster on PiV4
Wed Jan 22, 2020 2:21 pm
Can I assume that a Pi V4 with BUSTER (Sept 2019) will not connect to a router running WEP "security"?
I just checked with an older install of Buster (fully undated) on a PiV3 and WEP does work for that unit. Does that make a difference or are there extra steps for WEP on a PiV4? The wpa_supplicant.conf files are the same on both units....
Is there any work around? I'm at a location where they are not using something more secure and they do not want to change....RDK
Re: No wifi connection with Raspbian-Buster on PiV4
Wed Jan 22, 2020 9:58 pm
Get them to disable security completely - turn it into an open network, because that's functionally equivalent to a network with WEP.
You can encourage wpa_supplicant to connect to WEP, but you can't do that with the taskbar widget.
https://www.raspberrypi.org/forums/view ... hp?t=88644
RDK
Wed Jan 22, 2020 11:57 pm
Thanks Dougie, but it still does not connect. Here is my wpa_supplicant.conf, which is what was recommended in your link.
update_config=1
country=US
network={
        ssid="Rosetown"
        key_mgmt=NONE
        wep_key0=911A0F4BC6
        web_tx_keyidx=0
At the risk of repeating myself, could this have something to do with the PiV4's?....RDK
Thu Jan 23, 2020 8:51 am
The WiFi software stuff should be identical.
I can't test this for three reasons
1. I don't have a RPi4B
2. I won't have a router/AP with WEP because my network security matters to me
3. Today, I've got no internets due to a BT/Openreach/Plusnet fault (so I'm currently tethered to my mobile phone)
RDK
Mon Jan 27, 2020 10:08 pm
I'm not having a lot of luck with Buster on PiV4B and WiFi!!!
I just tried to connect to a "good" WPA secure router with my Pi V4B Buster configuration. Running
 raspi-config
for WiFi I get the following error message:
Could not communicate with wpa_supplicant
and then to exit
raspi-config
I also get this one:
There was an error running option N2 Wi-fi
I just rebuilt a PiV3B+ with Buster and had no problems connecting. Any ideas?....RDK
ps....wired connections work just fine.
MrEngman
Mon Jan 27, 2020 10:34 pm
update_config=1
country=US
network={
        ssid="Rosetown"
        key_mgmt=NONE
        wep_key0=911A0F4BC6
        web_tx_keyidx=0
Is this a typo or what is actually in your file web_tx_keyidx=0. It should be
        wep_tx_keyidx=0
MrEngman
RDK
Mon Jan 27, 2020 10:47 pm
Good eyes!! TYPO in file. I will fix it and try again. Thanks....RDK
Regarding my last post (different Pi V4) about
. I did an apt update and upgrade and rebooted several times and now noticed that wifi is connecting. Go figure....RDK
RDK
Mon Jan 27, 2020 11:44 pm
Correcting my spelling did t he trick. Thanks....RDK
