Static IP address
Posted: Sat Jan 18, 2020 8:56 pm
by techforay
I am trying to give my Raspberry Pi 4 running Raspbian buster a static IP address. I am new to this and am trying to learn. I have been modifying the dhcpcd.conf file. I can get the ip to change but I wont connect to the internet after it is changed. I have tried to follow a couple of YouTube videos and may have messed up my dhcpcd.conf file although I am connected now through dhcp. I have two questions
1. Is there some place to get the default dhcpcd.conf file so I can get back to where is started
2. Can I get some instruction on setting up static iP addresses. I remote into it and lose the ability every time the IP address changes. Thank you in advance for your help.
I have copy and pasted the file below
#interface wlan0
#static ip_address=http://10.0.0.32/24
#satic router=10.0.0.1
#static domain_name_servers=127.0.0.1
# A sample configuration for dhcpcd.
# See dhcpcd.conf(5) for details.
# Allow users of this group to interact with dhcpcd via the control socket.
#controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
# Some non-RFC compliant DHCP servers do not reply with this set.
# In this case, comment out duid and enable clientid above.
#duid
# Persist interface configuration when dhcpcd exits.
persistent
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
clientid
# or
#duid
persistent
option rapid_commit
# A list of options to request from the DHCP server.
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
# Respect the network MTU. This is applied to DHCP routes.
option interface_mtu
# Most distributions have NTP support.
#option ntp_servers
# A ServerID is required by RFC2131.
require dhcp_server_identifier
# Generate SLAAC address using the Hardware Address of the interface
#slaac hwaddr
# OR generate Stable Private IPv6 Addresses based from the DUID
slaac private
#option ntp_servers
#slaac hwaddr
slaac private
# Example static IP configuration:
#interface eth0
#static ip_address=http://192.168.0.10/24
#static ip6_address=fd51:42f8:caae:d92e::ff/64
#static routers=192.168.0.1
#static domain_name_servers=192.168.0.1 8.8.8.8 fd51:42f8:caae:d92e::1
# It is possible to fall back to a static IP if DHCP fails:
# define static profile
#profile static_eth0
#static ip_address=http://192.168.1.23/24
#static routers=192.168.1.1
#static domain_name_servers=192.168.1.1
# fallback to static profile on eth0
#interface eth0
#interface eth0
#fallback static_eth0
#added the below for USB-C connection
denyinterfaces usb0
#interface eth0
#static ip_address=10.0.0.100
#interface wlan0
#static ip_address=10.0.0.99
#static routers=10.0.0.1
#static domain_name_servers=8.8.8.8 8.8.4.4
Re: Static IP address
Posted: Sat Jan 18, 2020 10:12 pm
by dustnbone
Remember that for a line to be valid you need to uncomment it.
Lines beginning with # are considered comments and will be ignored by the daemon, so you must remove that # from lines you want to "use"
This convention applies to most configuration files in Linux.
Personally, I prefer to configure my router to give a static DHCP lease to systems that need the same IP all the time, and just allow DHCP to act as normal. You tell the router the MAC address of the Pi, and when it gets a DHCP request from that MAC address it assigns it the correct IP.
How this is done varies depending on your particular router, but it's usually in the configuration pages under "Static Lease" or "DHCP Reservation" or something similar.
Posted: Sat Jan 18, 2020 11:04 pm
by techforay
Yes i know about the # commenting things out. Those are all the things i tried to get the static ip address to work. That is why i asked if i could find a clean file out there to get it back to the default.
Posted: Sat Jan 18, 2020 11:23 pm
by epoch1970
Static IP address: https://www.raspberrypi.org/documentati ... /README.md
To get back to the original config file, just reinstall the package: “apt-get install --reinstall dhcpcd5”
(or look for instructions on how to download a debian package without installing it, and how to unpack it.)
Posted: Sun Jan 19, 2020 12:23 am
by LTolledo
I also set my router to reserve IP address for my devices (PCs, smartphone, SBCs like the RPi, etc). This is only applicable if I have admin rights to the routers.
so even if the device changes location to a different router.... the device can still get another IP address on that other router (may be static if reserved there, otherwise its auto)
Posted: Sun Jan 19, 2020 3:31 am
by GlowInTheDark
I know that the "supported/approved answer" to this sort of thing is to "do it in the router" (as the last few responses attest), but the problem with that is that the reason people want to use static IP in the first place is because they either can't use or don't trust the DHCP server. I.e., you use static IP when the normal stuff isn't working. If the normal stuff is working, then you'd just do normal DHCP.
Yes, yes, I know some smart people here will come up with exceptions, reasons why they need static IP and why they do it the way they do it, but (short version) those reasons don't matter. They don't apply to the sorts of people and situations that cause these sorts of threads to be started.
Posted: Sun Jan 19, 2020 3:54 am
by dustnbone
I guess in this case I assumed (not necessarily correctly) that since OP was accessing the Pi from outside the LAN, via port forwarding, they had access to the router configuration. They want a consistent IP on the Pi so that port is forwarded to the correct device on the LAN.
The reason that doing it from the routers DHCP server is preferred IMHO, is to avoid IP conflict in the case of the routers DHCP assigning the IP configured on the Pi to another device on the LAN.
So, if you ARE going to assign a static IP to a device on a network that has an active DHCP server running, you need access to that DHCP servers configuration in order to ensure your static IP is outside the range of automatically assigned addresses.
Posted: Sun Jan 19, 2020 4:42 am
by ejolson
Configuring the DHCP server in the router to assign the same IP number to the Pi based on its MAC address is a good and convenient solution. My home router is too simple to allow this, but it did allow me to configure the range that it will issue leases for. Thus, I've set the DHCP server to assign numbers in the range from xxxxxxx.128 to xxxxxxx.254. This leaves xxxxxxx.2 through xxxxxxx.127 for any static numbers I want to assign and there is no chance of collision that way.
Posted: Sun Jan 19, 2020 8:42 am
by rpdom
This is true. I do use reserved addresses via DHCP (I disabled dhcp on my router - it is handles by a Pi running dnsmasq instead, which is more flexible), but I do have a couple of Pis where I have fixed the IP address in dhcpcd.conf because they need to have those IP addresses even if they can't contact the DHCP server for any reason.
Posted: Sun Jan 19, 2020 10:47 am
by epoch1970
Well the network doesn’t really care for your situation or your reasons. Either you follow the established protocol and you can communicate, or you don’t, and have trouble. Dura lex sed lex.
Without the help of DHCP, establishing a guaranteed working manual static IP address for a host requires the talent of a mind reader. Unless you are the admin of that network, or you are willing and able to do some detective work.
Lease reservation via DHCP is the best practice and usually ISP routers make that pretty easy.
Posted: Sun Jan 19, 2020 12:01 pm
by rpdom
Pretty much everyone with a home router is the admin of their network, whether they realise/understand it or not.
Posted: Sun Jan 19, 2020 12:07 pm
by GlowInTheDark
Just so you know, if the last few responses are in reference to my post and if they are supposed to convince me that I was wrong in some way, I just want you to know that you're talking to the hand.
If this is not the case, then, of course, please disregard this post...
Posted: Sun Jan 19, 2020 12:18 pm
by rpdom
Um, I mostly agreed with you. But if you want to ignore that, fine. I shall put you on my ignore list.
