I'm working on a DIY project for measuring power consumption from my electricity meter using a serial connection interface on the meter.
I'd really like to power a Raspberry Pi Zero W or similar directly from the meter, so I don't have to pull wires from somewhere else.
There is a power output (VCC-pin) inside the electricity meter, but it is below the usual 5V required by a Raspberry Pi, and I am wondering whether the voltage and amp is enough to be converted to something a Raspberry Pi W Zero could run off of?
Hope you can help a beginner out.
