PeeWee
Screen Capture Program
Wed Dec 19, 2012 10:34 am
Does anybody know of a screen capture program that I can us on my Raspberry Pi.
I normally use Shutter to take screen shots on my Ubuntu operated Toshiba laptop. However, I would like to use my Pi to take screen shots as part of my work writing user guides.
Regards
PeeWee
Hiro
Re: Screen Capture Program
Wed Dec 19, 2012 9:02 pm
How about giving the command line utility Scrot a try? It's very simple to use and a tiny install. A simple how-to can be found here. http://www.freesoftwaremagazine.com/art ... with_scrot
flyinghappy
Wed Dec 19, 2012 9:08 pm
I second the use of scrot. Works very well on my desktop.
scrot -c 5
gives me a 5 second delay before taking the shot.
Pi with ArchLinux running a minidlna/samba home server
PeeWee
Thu Dec 20, 2012 12:51 pm
Thank you for the help. Scrot works perfectly and so simple to operate. Just have to memorize the line commands now as I have been so used to clicking buttons.
Regards
PeeWee
mad-hatter
Thu Dec 20, 2012 1:24 pm
ksnaphot - has a front end
Regards
JimBurke
Tue Mar 29, 2016 10:21 am
This is fine when you are using the X desktop. There are a few screen capture/manipulation apps such as this.
HOWEVER, what about if you are running WITHOUT an X server ? For example, you are running a java app on the console and you want to screenshot it ?
Any ideas ?
Jim
klricks
Tue Mar 29, 2016 12:45 pm
JimBurke wrote:This is fine when you are using the X desktop. There are a few screen capture/manipulation apps such as this.
Any ideas ?
Jim
I do screen captures [Alt]-[Print Screen] over a remote connection on a Windows machine. Either SSH (PuTTY) or RDP (remote desktop).
Tue Mar 29, 2016 5:12 pm
To capture the console framebuffer as an image, I think you can use fbcat
pi@raspi3 ~ $ apt-cache show fbcat
Package: fbcat
Version: 0.3-1
Architecture: armhf
Maintainer: Piotr Lewandowski <piotr.lewandowski@gmail.com>
Installed-Size: 57
Depends: libc6 (>= 2.13-28)
Recommends: netpbm | graphicsmagick | imagemagick
Conflicts: fbgrab
Replaces: fbgrab
Provides: fbgrab
Homepage: http://fbcat.googlecode.com/
Priority: extra
Section: graphics
Filename: pool/main/f/fbcat/fbcat_0.3-1_armhf.deb
SHA256: 04666865bbb43765a44618021c887381e92d57053dd096d20b685ec8e0e7d92b
SHA1: 1f2efcc1840f0d09347f99573e3c32dccf543224
MD5sum: f23d9d8578c20bdde29620001b5a5803
Description: framebuffer grabber
 fbcat grabs a screenshot of a framebuffer and stores in a PPM file.
 This package also provides a compatibility wrapper around fbcat to ease
 migration from fbgrab.
Description-md5: 37bef91d1c0a57141537400941ef2def
I haven't tried it myself.
Rive
Tue Mar 29, 2016 5:15 pm
"PrtScr" aka "print screen" on keyboard works also. as does the screenshot function in GIMP.
DNPNWO
kusti8
Tue Mar 29, 2016 5:16 pm
AndyD has a nice utility called raspi2png which I used to screenshot omxplayer.
https://github.com/AndrewFromMelbourne/raspi2png
Tue Mar 29, 2016 5:20 pm
Ok, now I've tried it and it seems to work
That's a low-res framebuffer because that Pi is running headless and defaulting to composite output. Also I've got it defaulting to a very large font.
I used "convert" from imagemagick to convert the generated ppm file to a png.
