James Langeford
Does the Raspberry Pi 2 is able to drive the DM542T stepper driver
Sun Dec 29, 2019 10:27 pm
I have been trying to use the DM542T to drive my NEMA 23 motor. When I hook up the GPIOs with the stepper motor driver, The motor is not turning at all. I've checked that the power is on. Furthermore, I used the same connections/set up with the Arduino and the motor spin. However, when I switch those connection to GPIOs of the Raspberry Pi, nothing works and I'm confuse as to why. From the way I understand it, the stepper motor driver only need 5V bias on PUL+ and DIR+, then I pull the PUL- high and low repeatedly to spin the motor. The same strategy works in Arduino but not in the Pi. Also, I check my PUL- pin with an LED to make sure that it is giving out output with my code, and sure enough, the LED works. I'm currently sitting at a lost right now.
nomdediot
Re: Does the Raspberry Pi 2 is able to drive the DM542T stepper driver
Sat Jan 04, 2020 7:41 am
Arduino outputs are 0-5v while rpi is only 0-3.3v. Maybe it s the reason?
You should check with the driver if 3.3v is accepted, else you can increase output voltage with a voltage translator ic.
Else I see no reason why the pi can t drive it.
pcmanbob
Sat Jan 04, 2020 10:30 am
Hi.
The DM542T requires a 5V supply to operate its control inputs it clearly states that on the controller, to drive the controller inputs from the pi 3.3V gpio you need to add a transistor driver circuit for each input.
https://www.omc-stepperonline.com/downl ... VCuJj7MUIp
like this
randyrtx
Wed Apr 08, 2020 3:12 am
Thank you for this..It took me a bit to realize when you go hi out the Pi output you are really giving it a low to the controller.
So this is my "hello world" version of the code necessary to talk to the motor. spins right then spins left based on how many times and speed (enter 1 - 100)
#!/usr/bin/python3
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BCM)
on = GPIO.HIGH
off = GPIO.LOW
pul = 16
dir = 20
ena = 21
GPIO.setup(pul,GPIO.OUT)
GPIO.setup(dir,GPIO.OUT)
GPIO.setup(ena,GPIO.OUT)
GPIO.output(dir,off)
GPIO.output(pul,off)
GPIO.output(ena,on)
time.sleep(.0001)
GPIO.output(ena,off)
time.sleep(.0001)
def moveright(rotate):
    for i in range(rotate):
      GPIO.output(pul,on)
      time.sleep(.001/int(speed))
def moveleft(rotate):
    GPIO.output(dir,on)
    time.sleep(.0001)
      GPIO.output(pul,on)
howmany = input("Please enter how many times to steps: ")
print("You entered: " + howmany)
speed = input("Please enter how fast to step: ")
print("You entered: " + speed)
moveright(int(howmany))
time.sleep(.0001)
moveleft(int(howmany))
GPIO.cleanup()
pcmanbob
Wed Apr 08, 2020 10:59 am
That's not quite right,
when you output a high on the gpio pin , you turn the transistor on , which provides a ground to the LED on the selected input.
then then turns on the opto isolator in the controller.
So the high output on the gpio results in a high input to the controller , its just that you are switching a ground to achieve this.
Glad you got it all working, many people seem to struggle with this type of controller.
