#4. mentioned
If the input impedance is too high, say 100MΩ, then you'd need only 50nA to get 5V. This would make the input far too sensitive
Yes I know the calculation and this indeed follows the ohms law. However, my question is that in order to make the pin read a HIGH signal, what can the pin control is that "how much current should it draw" but not "how much voltage can the environment apply". From my understanding, as long as the environmental factor cannot provide 5V, then the 100MΩ can never take 5V.
Base on my assumption above, my questions are:
1. How can a high impedance input GPIO be so sensitive if the the environmental factor(volt) cannot be controlled by the GPIO pin? (just like you won't get a 5V circuit from a single 3.7V 18650 battery)
2. is it a truth that environmental factor can make a 5V voltage difference into the high impedance GPIO input pin?
