Overclock using the Berryboot
Posted: Sat Dec 28, 2019 5:21 am
by Tarsis
Hi everyone,
I would like to know how I can set my raspberry to overclocking mode to be able to play psp games on the retropie for example. I found several tutorials teaching how to change frequency parameters and others by editing the config.txt document in the raspberry boot directory. But as I am running the OS's through berryboot the document config.txt that is in the boot directory is completely different from what I saw in the other tutorials. I will copy below the config.txt that is saved in the sd card. If anyone knows how I can overclock raspberry I appreciate it very much.
start_x=1
gpu_mem=160
# Enable on-board audio
dtparam=audio=on
# Berryboot settings, do not change
initramfs bbloader.img
kernel=kernel_rpi0123_aufs.img
[pi3]
# Uncomment this line before installation if you want to enable USB boot
#program_usb_boot_mode=1
# Uncomment this line to prevent continuous SD card polling if using USB/PXE boot
#dtoverlay=sdtweak,poll_once
[all]
Best Regards.
Re: Overclock using the Berryboot
Posted: Sat Dec 28, 2019 10:26 pm
by incognitum
Just add your overclock settings either at the top of the file, or at the bottom under [all]
Leave existing stuff as-is.
