Looking for some Input Regarding Pi Zero
Posted: Wed Dec 11, 2019 9:57 pm
by jcdale
Greetings!
I'd like to run a Pi Zero with a small java process that captures 44k mono wave from an external sound card.
I have this working on a pi III and it's hardly touching the CPU.
Will a pi zero be okay for this?
I want it on a hardwired ethernet, so I assume I'll need a usb adapter, power supply, and ethernet adapter.
Sound about right?
What can you recommend?
Sincerely,
John
Re: Looking for some Input Regarding Pi Zero
Posted: Wed Dec 11, 2019 10:37 pm
by rpiMike
I guess a pi zero would be ok, this might be useful:
https://thepihut.com/products/adafruit- ... -connector
Posted: Thu Dec 12, 2019 2:51 pm
by jcdale
Is the difference between a Raspberry Pi Zero W and a Raspberry Pi Zero (no "W") the components it ships with? I really don't want any wireless on it at all ..
Posted: Thu Dec 12, 2019 3:04 pm
by DougieLawson
The difference is that the W has on-board WiFi. Nothing more.
Posted: Thu Dec 12, 2019 3:51 pm
by rpdom
and Bluetooth.
Posted: Thu Dec 12, 2019 4:01 pm
by thagrol
And onboard bluetooth ;)
Posted: Thu Dec 12, 2019 4:17 pm
by DougieLawson
BT, who uses that apart from the other Douglas?
Posted: Thu Dec 12, 2019 7:57 pm
by scruss
Java doesn't work very well (at all?) on the Raspberry Pi Zero. You may have to install the Oracle version. But tbh, adding all the extra USB stuff will make the device as big and expensive as a Raspberry Pi 3B+.
I do, but he answers all the questions.
Posted: Sat Dec 14, 2019 3:22 pm
by jcdale
What would you recommend I do to order what I'm looking for in the US?
Amazon seems to not have what I need ..
John
Posted: Sat Dec 14, 2019 9:06 pm
by scruss
Try Chicago Electronic Distributors - https://chicagodist.com/ - a US based official reseller who also sells Pimoroni.
(disclosure: I used to work for the Canadian sister company of CED and the owner is still a good friend.)
