PiesAreSquared
How to install Azure CLI on Raspberry Pi
Tue Dec 10, 2019 11:44 am
Does anybody have a solid method for installing the Microsoft Azure CLI on a Raspberry Pi? There is a Debian-compatible distribution of the Azure CLI but it doesn't work with ARM CPUs and I get errors with the "az" command if I install it. I've tried Docker container versions, which work up to a point but require "sudo docker exec cli az.." to preface every command, which is a pain. Ultimately I need /usr/bin/az to either work straight off, or to link to some code (in a container?) that works.
Thanks!
topguy
Re: How to install Azure CLI on Raspberry Pi
Tue Dec 10, 2019 1:16 pm
Where did you find the docker images ? ( If you dont link to what you have tried, people might just suggest the same resources. )
mastro35
Sat Jun 27, 2020 10:33 am
It’s not a solution, just a workaround... but you could just alias “sudo docker exec cli az” to “az”...
