T3rr0rByte13
5 Servos and a Stepper Motor
Mon Dec 09, 2019 1:25 am
I'm looking for the best way to hook up 5 servos and a Stepper motor to a single Raspberry Pi. I can figure out the programming I just don't know the best way to physically connect all these. Can you please help? Thanks!
pcmanbob
Re: 5 Servos and a Stepper Motor
Mon Dec 09, 2019 11:43 am
From the little information supplied....
If they are just standard small servos you would connect them 5 gpio pins to provide the control signals , but you would need to power them from a separate power supply,
the stepper motor will require a drive board of some type dependant upon which stepper motor you intend to use, again using 3 or more gpio to provide the control and a separate power supply to power it.
T3rr0rByte13
Sat Dec 14, 2019 5:04 am
Thanks pcmanbob, I have located a few driver boards from Adafruit that may suit me. I'll have to figure out how I am gonna power these. Thinking a barrel connector to Positive Negative output. Plugged into a wall... we will see.
