Hi there, I am new to electronic side of RPI. I owned a RPI 4B at the moment. And I have several question about RPI GPIO pins.
May I know if I will burn my GPIO in the follow scenarios?
1. Accidentially provide a large voltage to my RPI's 3.3v GPIO pin, e.g. 10v? (I would keep the current at 0.6mA, will it burnt?)
2. Accidentially provide a 3.3v to a GPIO pin which is configured as an output pin. (again, I would keep the current at 0.6mA, will it burnt?)
3. If any of the above question will burn the RPI? May I know how would that be done? In my merely knowledge, because V=IR. Providing any device with a voltage which is large than which is rated will lead to a large current drawn. However, RPI's GPIO won't control/limit its current drawn. Does it mean that it won't burnt as long as I keep the current low at 0.6mA?
Thanks in advance.
