Actual Working Guide on how to auto-start Chromium at 200% zoom
Posted: Thu Dec 05, 2019 12:13 am
by gprimr1
Does anyone have an actual working guide on how to auto-launch Chromium on startup to a website and zoom to 200% with a Raspberry Pi 4 with Rasperian Buster ?
I've searched the web and found about 20 different guides, and every one of them ends up with "file not found" or "error" at some point and doesn't work. I tried Binary Motions program, but it doesn't support zooming so I can't use that.
It's maddening that such a simple thing seems next to impossible.
Re: Actual Working Guide on how to auto-start Chromium at 200% zoom
Posted: Thu Dec 05, 2019 1:39 am
by klricks
A quick Google turned up this command:
chromium-browser --force-device-scale-factor=2.0 www.raspberrypi.org
Note that 2.0 means 200% .... Adjust as necessary.
Add the above command to whats already in autostart:
sudo nano /etc/xdg/lxsession/LXDE-pi/autostart
Posted: Thu Dec 05, 2019 3:16 am
by gprimr1
Now I feel dumb.
I've been working on this for 3 days and I guess I never saw the "sudo" in front of nano, so I was going through all of these guides and every time I did nano /etc/xdg/lxsession/LXDE-pi/autostart I got "no such file or directory"
Posted: Thu Dec 05, 2019 9:39 pm
by flaco_in_tx
Great info! I've been having to hit ^+ a number of times at every webpage I hit. Imagine how lucky I feel finding this fix!
Not being much of a CLI guy though, I have two questions:
1. Can I substitute firefox-browser for chromium-browser, and
2. it looks to me (again, I'm pretty ignorant) as if this fix only works at this site?
Thanks - Flaco
Oh, it just occurred to me: If #1 (above) works, then can I have a separate line for both firefox and chromium?
Posted: Fri Dec 06, 2019 4:38 pm
by klricks
Thanks - Flaco
The command above is only an example. You can use any URL or more than one URL can be specified to open multiple tabs at once.
Pretty much any command(s) or program(s) can be started with autostart. You just need to find the CLI command. For example to start filemanager use:
pcmanfm
Not sure why you would want to run firefox and chromium at the same time?
Posted: Fri Dec 06, 2019 6:06 pm
by flaco_in_tx
Thanks - Flaco
pcmanfm
I don't, but:
Ah. I think I see now--I seem to have misread what OP wanted, which you solved.
I think I'll dig into the browsers' directories, not autostart, as I'm looking to set browser parameters, not to autostart a browser at boot.
Sorry for my confusion; no hijack intended.
Thanks, Flaco.
Posted: Fri Dec 06, 2019 6:54 pm
by flaco_in_tx
I found what I needed in firefox in:
about:config
font.size.systemFontScale 133 (was 100 by default)
Duh :roll:
I'll google duck-go up how to change chromium parameters.
We now return you to your normally scheduled forum.
-flaco
