ReadiesCards
How do I setup a mini-httpd webserver?
Fri Dec 14, 2012 7:32 am
From this month's 'The MagPi' I have learnt of the existance of mini-http
But I can't get it to work and would appreciate some advice. Here is what I have done so far (using latest Raspbian “wheezy”:
Installed mini-http:
$ sudo apt-get install mini-httpd
Questions:
* is there a good reference for mini-httpd (I came across many but could not work out which was the ultimate reference)
* how do I start it
* how do I make it auto-run on boot up
* do I need to make a log file directory for it (one Google search suggested so) if so where (or is it auto created)
* if I want to run it as root (!) to allow cgi access to GPIO how do I do that
* where should I put my html files
Any advice most welcome
Paul
ReadiesCards
Re: How do I setup a mini-httpd webserver?
Fri Dec 14, 2012 5:57 pm
Should I ask this in a different forum section, if so which?
Paul
bgirardot
Fri Dec 14, 2012 6:34 pm
1. It does not look like the author provides much documentation beyond the man page so anything you find on the web is probably fine to go by. But you can:
man mini-httpd
to see the documentation the author provides.
2. The debian service manager can start/stop the server:
sudo service mini-httpd start
3. Looks like it will auto run on system start by default.
4. Looks like it logs to the standard place by default: /var/log/mini-httpd.log
5. Edit /etc/mini-httpd.conf
6. /usr/share/mini-httpd/html by default
You will need to read and edit:
/etc/default/mini-httpd
before the server will run.
Hope that helps some. Cheers.
ReadiesCards
Sat Dec 15, 2012 7:11 am
Thank you!
That was exactly the information I needed I.e. how to start it.
