david_1234
INA219 problem
Mon Nov 04, 2019 10:27 am
Hello ,
I'm trying to use INA219 device to check device volt\amp
when I connect the INA219 to the pi for the first time I can see it in the scan :
 sudo i2cdetect -y 1
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: 40 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
but after a few minutes , I don't see the INA219 (without doing\running nothing)
sudo i2cdetect -y 1
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
I have disconnected the external device and restart the pi - still can't see nothing
I have try 3 INA219 - in all of them I get the same problem (work only 1 time for a few minutes)
the external device is working with 18V and use 0.4A (which is in the limitations of the INA219 (26V/3.2A)
the INA219 connections are:
PI3 - INA219
pin 1 - 3.3V
pin 3 - SDA
pin 5 - SCL
pin 39 - GND
also I have notice that if the INA219 is not getting power (3.3V) the scan is much faster .
what could be the problem ? reason it doesn't work?
Thanks ,
