up until now I run my code on PI3-stretch
wanted to know if there are any changes I need to do in the setting when moving to buster ?
I want to remove the pi icons at startup,diable the black screen after 10 min , show my own logo in boot
this is what I did until now:
Sudo nano /boot/config.txt
Add this line:
disable_splash=1
Sudo nano /boot/cmdline.txt
Add this to the end of the line
logo.nologo
change the image splash.png (with my own image) in
/usr/share/plymouth/themes/pix/
sudo nano /home/pi/.config/lxsession/LXDE-pi/autostart.txt
@lxpanel --profile LXDE-pi
@pcmanfm --desktop --profile LXDE-pi
@xset s noblank
@xset s 0
@xset -dpms
point-rpi
@chromium-browser --start-fullscreen --start-maximized /home/pi//angular-node/src/startPage.html
upload the memory to 1024 in: ---? do I still need to do this? (I'm using PI4 4G)
sudo nano /etc/dphys-swapfile
****Update****
I have try to run with this setting:
I don't see the 4 pi icons at startup
I don;t see the splash.png image I have uplaoded
and it's seem that this command is not working
The browser is not open on startup
but if I run the command on the CMD - it's working and my code \webpage is running with out any problem
why?
