nick8967
what does cd $cwd do?
Thu Oct 17, 2019 2:14 pm
What this command does?
cd $cwd
B.Goode
Re: make -j4 command on OpenCV makes RaspberryPi 3 B+ stuck
Thu Oct 17, 2019 2:24 pm
cd $cwd
(No obvious relationship to the substantive question in the thread in which this was originally posted ... )
From the output of
man cd
cd - Change the shell working directory
$cwd is an environment variable.
gkreidl
Re: what does cd $cwd do?
Fri Oct 18, 2019 8:50 am
Nothing!
It means "change directory to current working directory" but this is where you already are (inside a terminal).
Minimal Kiosk Browser (kweb)
deepo
Fri Oct 18, 2019 9:15 am
Nothing!
Not necessarily true.
$cwd is a variable that I guess the OP found in a script somewhere.
If you are logged in as e.g. pi and are currently in the / folder and then type cd $cwd from a terminal, then that will result in a cd command that will change directory to your home directory, because the $cwd variable is empty.
/Mogens
Fri Oct 18, 2019 9:24 am
Nothing!
Is cwd a shell built-in variable? I know PWD is, but don't think cwd is. Perhaps cwd has been set elsewhere?
Unreadable squiggle
PeterO
Fri Oct 18, 2019 11:02 am
I will admit to having to check as my first thoughts were that $cwd existed though I was suspicious about $cwd vs $CWD,
$PWD does exist (at least on login shells running bash, but neither $cwd or $CWD exist by default, (AFAICT)
PeterO
