rbscebu
[SOLVED] How Do Dual Monitors On The RPi4B Function?
Fri Oct 18, 2019 4:49 am
I now have my RPi4B 4GB almost set up the way I want it as my computer system, currently using a single monitor. I am interested in trying out the RPi4B with dual monitors. Before I go the added expense of buying another monitor, I have a question.
With the RPi4B set up using dual monitors, can I have one monitor say playing a video while I simultaneously use the other monitor for word processing?
RPi4B 4GB with Raspian Buster
RPi3B+ with Raspian Buster
RPi0W with Raspian Buster
Gavinmc42
Re: How Do Dual Monitors On The RPi4B Function?
Fri Oct 18, 2019 5:22 am
If you want too, I would rather code.
Most DVI monitors just need a HDMI to DVI adapter and old DVI monitors are free or cheap.
Two 21:9 curved monitors should work too if you have the money :D
The cables need small ends so they can fit.
The Official cables work well and are not very expensive.
I'm dancing on Rainbows.
rbscebu
Fri Oct 18, 2019 5:32 am
I am 67 years old. I spent 10 years many years ago coding in Fortran IV and V before specialist software was available for my profession. Now I prefer to design ships.
Thank you for your reply. I assume that your reply means that I can have a different program running simultaneously on each monitor. That is what I need to be able to do.
Fri Oct 18, 2019 6:42 am
What you want to do is irrelevant to the OPs question. So why state it?
PeterO
Fri Oct 18, 2019 7:05 am
The two monitors are combined into a single logical desktop, so you can move application windows between the two.
You can adjust the logical layout of the two screens, "left/right" or "above/below" to match the physical layout.
You can certainly watch videos in a browser window (or in "full screen" **) on one monitor and and have other applications (e.g. email) on the other monitor.
HTH
PeterO
** "full screen" is now "half desktop" :-)
rbscebu
Sat Oct 19, 2019 12:38 am
Thank you for the replies. Looks like it will be beneficial to me to have a dual monitor setup. I will order another monitor next week after I return home from HK.
