What folders to backup, if I want to clone the device?
Posted: Mon Oct 14, 2019 7:27 pm
by Sulforaphane
What folders should I backup, if I want to clone my Raspberry Pi?
Re: What folders to backup, if I want to clone the device?
Posted: Mon Oct 14, 2019 8:12 pm
by B.Goode
If you are running the recommended and supported Raspbian Buster Operating System, simply use the provided SD Card Copier utility and let that make the clone.
(But otherwise: if you want a clone, ie. an exact replica, you need to backup everything.)
Posted: Mon Oct 14, 2019 8:18 pm
by Sulforaphane
Thanks!
Posted: Mon Oct 14, 2019 8:25 pm
by rpdom
Do note that if you are looking at the SD card in something like a Windows system you will only see a small number of the files required. This is because Windows does not understand Linux file systems, so ignores them.
Posted: Mon Oct 14, 2019 10:11 pm
by thagrol
Or asks you to reformat the partition to something it does understand. Which you shouldn't do coz you'll lose everything in it.
Posted: Mon Oct 14, 2019 11:04 pm
by RossDv8
If you run the SD card copier in 'Accessories' in your menu, it may be better NOT to use a smaller SD card unless you are sure it has enough space to take 'everything' that is on the card you are using :) (Easy to do if you forget your glasses).
It is handy to have a spare card with everything on it Justin Case. I clone mine every couple of weeks just to take a complete backup including new programs I have added, SD Card Copier is a very, very handy tool.
Posted: Tue Oct 15, 2019 2:48 am
by rpdom
If you run the SD card copier in 'Accessories' in your menu, remember NOT to use a smaller SD card :) (Easy to do if you forget your glasses).
Why not?
As long as the card being copied to has sufficient space for all the files and a bit left over, it'll be fine.
Posted: Tue Oct 15, 2019 5:21 am
by RossDv8
I modified my answer to suggest one should check if the destination card has sufficient space :-)
