martyp
Unable to install mysql
Wed Oct 09, 2019 5:38 pm
Hi all,
Following the failure of an SD card I need to restore a project and the image was originally on Raspbian Wheezy which I believe is now out of date. I can't install mysql server as it comes up with lots of 404 not found messages and a failure at the end.
I understand there's a workaround to fix this as it's been archived but unsure how you do it? Please can someone help?
fbe
Re: Unable to install mysql
Wed Oct 09, 2019 5:50 pm
If you need access to a Raspbian Wheezy repository, this topic may help: https://www.raspberrypi.org/forums/view ... p?t=242895
The most recent Raspbian with MySQL is Jessie.
MySQL is MariaDB (mariadb-server mariadb-client) in Raspbian Stretch and Buster
You should not expect to get much help here for Raspbian older than Stretch and even Stretch gets outdated.
martyp
Wed Oct 09, 2019 10:54 pm
Excellent, thanks fbe
Return to “Beginners”
