HawaiianPi wrote:
@ LTolledo,
Have you tried a large file copy operation between the two HDD, or configuring them as a RAID?
Nope, didn't tried it when I posted it, as I needed to "recharge my internal batteries"
Did tried some file copy later on... a single 500MB file from a network share to each HDD, and it did copy successfully
but coping between the two drives failed, as the drives "ejected" themselves, only to return back again a few seconds later
if copying smaller files (anything below 15MB) you'll probably get away with it, bigger than that and the drives "eject" themselves.
so the conclusion here
Yes you can attach 2 bus powered hard drives, if you really want to attach 2 bus powered hard drives
Yes you can copy large files to any one of the two bus powered hard drives, as long as you do the copy 1 drive at a time...
No you cannot copy large files between the 2 attached bus powered hard drives, but "may be able" to copy if the file size is less than 15MB.
However.....
you can attach 2 (or more*) self powered hard drives (which is a better choice), or 2 (or more*) bus powered hard drives connected to a "RPi compatible" powered USB hub. (note here: not all USB powered hubs work with the RPi)
you will be able to copy large files between the two (or more) attached hard drives (as long as those are self powered or connected to a powered USB hub)
you'll need to wrestle with tidying the wiring of the power for the RPi and the self powered devices...
* depends on RPi board.
...and then there is this somebody who blurted out "....just attach the two hard drives to the RPi using hot glue... no problem...!"
