sbaratheon
Cron
Tue Dec 11, 2012 6:11 pm
I'm trying to use cron but when I type:
sudo crontab -e
It says there is no crontab for root and it's using a temporary one :
no crontab for root - using an empty one
File: /tmp/crontab.nxsbBa/crontab
I save the file using Ctrl and O but it doesn't work.
What am I doing wrong here?
Thanks!
Joe Schmoe
Re: Cron
Tue Dec 11, 2012 6:17 pm
Why use sudo?
sbaratheon
Re: Cron
Tue Dec 11, 2012 6:22 pm
No reason.
I get the same problem with:
crontab -e
File: /tmp/crontab.Mdibr4/crontab
Joe Schmoe
Re: Cron
Tue Dec 11, 2012 6:40 pm
Well, I didn't say that not using sudo would solve your (non-existent) problem. I just wondered why you were using it. As you've correctly surmised, there is no reason to use it (unless you really do want to edit root's crontab file rather than your own).
As to your non-existent problem, it looks like things are working as they should. You don't have a crontab file (yet), but you want to create one. Once you create it, and save it, everything should be hunky-dory.
Incidnetally, the way the crontab editor works, is to make up a silly filename, edit that file in your $EDITOR, then, on exit from the editor, copy or rename that file to the "right" file where cron expects to find it. This is all working-as-designed.
sbaratheon
Re: Cron
Tue Dec 11, 2012 7:19 pm
Joe Schmoe wrote:Well, I didn't say that not using sudo would solve your (non-existent) problem. I just wondered why you were using it. As you've correctly surmised, there is no reason to use it (unless you really do want to edit root's crontab file rather than your own).
So running :
crontab -e
Adding:
***** /home/pi/tom/crontest.o
and saving should run every minute (cron is started btw)?
It doesn't, unfortunately.
pluggy
Re: Cron
Tue Dec 11, 2012 7:23 pm
Personally I'd edit the /etc/crontab file and tell it the user....
sbaratheon
Re: Cron
Tue Dec 11, 2012 7:37 pm
pluggy wrote:Personally I'd edit the /etc/crontab file and tell it the user....
I edited that with :
***** pi /home/pi/tom/crontest.o
and still nothing
pluggy
Re: Cron
Tue Dec 11, 2012 7:41 pm
It might need to be the root user. Usually if its unattended, running on a schedule, which user is 'running' it makes little odds.
jojopi
Re: Cron
Tue Dec 11, 2012 7:46 pm
sbaratheon wrote:***** /home/pi/tom/crontest.o
You need spaces between the asterisks.
What type of file is crontest.o, and is it executable? Conventionally, *.o are object files (compiled but not linked) and you can not run them.
The fact that you need to be root to edit /etc/crontab, but not to run "crontab -e", tells you that the latter is preferred.
pluggy
Re: Cron
Tue Dec 11, 2012 7:58 pm
I don't consider running unattended processes as root an issue. Nobody is logged in, the computer isn't going to mistype anything. Its only giving root permissions to the cron job in hand, so a rogue process isn't going to get to use it for its own ends. Theres a world of difference between running a cron job as root and logging in and running everything as root.
sbaratheon
Re: Cron
Tue Dec 11, 2012 8:01 pm
It's just a C++ executable which makes outputs the time in a file.
I've tried running crontab -e
adding * * * * * ./crontest.o
to no avail. What does the command actually need to be?
jojopi
Re: Cron
Tue Dec 11, 2012 8:15 pm
sbaratheon wrote:* * * * * ./crontest.o
You were better with the full path. The working directory when the command is executed will usually be /home/pi, but it is best not to rely on that.
Does the command behave as you expect when you run it manually?
sbaratheon
Re: Cron
Tue Dec 11, 2012 8:26 pm
only when I run cd to the directory and run "./crontest.o " not with "/home/pi/tom/crontest.o"
jojopi
Re: Cron
Tue Dec 11, 2012 8:33 pm
sbaratheon wrote:only when I run cd to the directory and run "./crontest.o " not with "/home/pi/tom/crontest.o"
Then obviously it will not work from cron without the cd. So try:
* * * * * cd /home/pi/tom && ./crontest.o
Or, add to the beginning of the source code:
chdir("/home/pi/tom");
And recompile. Preferably getting rid of the misleading .o suffix at the same time.
rgh
Re: Cron
Tue Dec 11, 2012 9:02 pm
Here's an example of it working, if it helps. This is on Raspbian.
First I create a crontab file for user richard:
[email protected] ~ $ crontab -e
no crontab for richard - using an empty one
crontab: installing new crontab
This is what it contains:
[email protected] ~ $ sudo cat /var/spool/cron/crontabs/richard
# DO NOT EDIT THIS FILE - edit the master and reinstall.
# (/tmp/crontab.FerJS8/crontab installed on Tue Dec 11 20:50:10 2012)
# (Cron version -- $Id: crontab.c,v 2.13 1994/01/17 03:20:37 vixie Exp $)
* * * * * $HOME/crontest.sh
This is what /home/richard/crontest.sh contains:
[email protected] ~ $ cat crontest.sh
#!/bin/sh
date > /tmp/log
and it is an executable:
[email protected] ~ $ ls -l crontest.sh
-rwxr-xr-x 1 richard richard 28 Dec 11 20:50 crontest.sh
So once a minute the current date is written in to /tmp/log (always assuming that file is writable by user richard).
Finally, you can look in the system logs and see that cron noticed I editted the file and you can see it is running it every minute:
[email protected] ~ $ sudo tail /var/log/syslog
Dec 11 20:49:07 raspberrypi crontab[4040]: (richard) END EDIT (richard)
Dec 11 20:49:19 raspberrypi crontab[4044]: (richard) BEGIN EDIT (richard)
Dec 11 20:50:10 raspberrypi crontab[4044]: (richard) REPLACE (richard)
Dec 11 20:50:10 raspberrypi crontab[4044]: (richard) END EDIT (richard)
Dec 11 20:51:01 raspberrypi /USR/SBIN/CRON[4052]: (richard) CMD ($HOME/crontest.sh)
Dec 11 20:52:01 raspberrypi /USR/SBIN/CRON[4064]: (richard) CMD ($HOME/crontest.sh)
Dec 11 20:53:01 raspberrypi /USR/SBIN/CRON[4088]: (richard) CMD ($HOME/crontest.sh)
Dec 11 20:54:01 raspberrypi /USR/SBIN/CRON[4092]: (richard) CMD ($HOME/crontest.sh)
Dec 11 20:55:01 raspberrypi /USR/SBIN/CRON[4157]: (richard) CMD ($HOME/crontest.sh)
Dec 11 20:56:01 raspberrypi /USR/SBIN/CRON[4166]: (richard) CMD ($HOME/crontest.sh)
sbaratheon
Re: Cron
Tue Dec 11, 2012 9:53 pm
Ok "cd /home/pi/tom && ./crontest.o" works but " * * * * * root cd /home/pi/tom && ./crontest.o" in etc/crontab doesn't work.
sbaratheon
Re: Cron
Tue Dec 11, 2012 9:55 pm
rgh wrote:Here's an example of it working, if it helps. This is on Raspbian.
#!/bin/sh
date > /tmp/log
Thanks for that. When I run crontab -e I get a file opened with instructions commented out. I simply add the cron command to the bottom and save. I don't get any message about "installing crontab"? When I run crontab -l afterwards I just get "crontab for pi".
rgh
Re: Cron
Tue Dec 11, 2012 10:21 pm
Sounds like you haven't actually saved the crontab. I don't know what editor you are using. I did this to use my favourite editor:
$ export EDITOR=vi
$ crontab -e
Maybe some combination of your editor and the way crontab -e works with a tmp file caused a problem. Try a different editor, perhaps.
efflandt
Re: Cron
Wed Dec 12, 2012 5:22 am
Perhaps a silly question, but who owns the executable and what permissions does it have for whom (ls -l), since it is in /home/pi instead of in /root? Maybe root does not have permission to execute it, or if permissions are too liberal, maybe root does not trust it.
Joe Schmoe
Re: Cron
Wed Dec 12, 2012 9:28 am
The bottom line here is:
1) There are lots of thngs that can go wrong when setting things up to run under cron - and if you're not familiar with it, then it will be a learning experience.
2) If you really do want something to run every minute, then I suggest that cron isn't the right vehicle for that. For a variety of reasons, running something every minute under cron can cause all sorts of issues, particularly during the development stages (i.e., when you don't have your program fully debugged). Instead, I suggest having the script contain its own "do it every minute" logic, like this:
while sleep 60;do
done
Now, the script just has to be launched once. And, finally, you should run it in a virtual console, not via cron. This can be done by modifying /etc/inittab to run this script on a VC (usually *not* tty1, BTW). Details will be provided if necessary.
sbaratheon
Re: Cron
Wed Dec 12, 2012 5:30 pm
Ah, got it working!
Thanks for everyone's help!
Dweeber
Re: Cron
Wed Dec 12, 2012 5:49 pm
If you are looking at your user account crons, you should never have to do such contortions like:
There is a command that lets you look at your user crontabs using... so if you are logged in as richard....
[email protected] ~ $ crontab -l
I also never use crontab -e .... prone to problems especially if you are using many different systems. if your editor settings are messed up or not right, you could end up with a blank crontab using crontab -e.
Instead, I teach my users to use a "process" of dealing with crontabs...
First get your current crontab entries:
$ crontab -l > cron.current
Then edit the file with your favorite editor....
Next save the changes using:
$ crontab cron.current
And ALWAYS check what you have with...
$ crontab -l
to make sure you did what you think you did.
This can also be used to keep copies of your crontab entries so that if you make a mistake, you can go back and see what you had. it is common to make a change to your crontab many days, months, years later....
Save an archive of what was there and a version you can edit...
$ crontab -l > cron.2012-12-11
edit
$ crontab -l
etc...
Dweeber A.K.A. Kevin...
My RPI Info Pages including Current Setup - http://rpi.tnet.com
