ghostinthepi
ADS 1115 Circut and configuration, i2cdetect -y 1 discovers nothing
Sun Oct 06, 2019 4:47 am
i2cdetect -y 1 is not discovering my device that I constructed, see the photo below possibly the soldering is botched or the wiring is bad? I'm not an excellent solderer.
https://photos.app.goo.gl/HSxBxhYkrHwnSqtg7
https://photos.app.goo.gl/dWyV6N4fTK6767Bc6
this is a raspberrypi 3 and this circuit is from "getting started with raspberry pi" 2nd edition; I've sometimes had to change thing because most examples are written for the raspberrypi 2
joan
Re: ADS 1115 Circut and configuration, i2cdetect -y 1 discovers nothing
Sun Oct 06, 2019 6:33 am
Could we have close-ups of the ADS1115 and the connections at the Pi. We need to be able to see how each pin is connected.
neilgl
Sun Oct 06, 2019 9:01 am
Yes and have you enabled the I2C interface on the pi using sudo raspi-config?
ghostinthepi
Mon Oct 07, 2019 2:06 am
Hi joan and neilgl,
https://photos.app.goo.gl/hSS8q3u3Dq7oqgpn6 - ADS1115 chip close up photo
https://photos.app.goo.gl/kYaKY8amAs3sK59r5 - to the PI wiring
https://photos.app.goo.gl/73ML1tSFZg2zQhBD7 - oblique of the device
https://photos.app.goo.gl/B8L1UHnXJvd7wxxh6 - angle of pentiometer
https://photos.app.goo.gl/cNW7sHEAsMfzTrKb9 - angle of chip wiring
Yes I have enabled the I2C interface on the pi using sudo raspi-config, for instance I see the
0 1 2 3 4 5
00: -- -- --
10: -- -- -- -- -- --
(etc) But there is no device connection/recognition by the pi.
Thank you
neilgl
Mon Oct 07, 2019 9:21 am
The soldering of the pins into the ADS1115 board looks a little messy so there could be a short circuit between some pins. Can you test that with a multimeter, or reflow the solder, removing excess solder?
pcmanbob
Mon Oct 07, 2019 9:30 am
looking at the soldering on the ADS board I would think there is a high possibility of a dry solder joint or 2 on there, as neilgl suggested I would redo the soldering , may be practising first on some strip board using some cheap resistors to improve your soldering technique.
You might also look at one of the many soldering videos on YouTube to see what your soldering joints should look like.
Mon Oct 07, 2019 9:31 am
All of those solder joints look dry.
https://learn.adafruit.com/adafruit-gui ... n-problems
ghostinthepi
Tue Oct 08, 2019 3:53 am
pcmanbob, DougieLawson, neilgl, joan
Thank you for your insights it is truly appreciated. I'm going to move forward with the help from your responses. After practicing some soldering I will return to the chip and try to salvage my first mistakes and follow up with a post, hopefully with a successful signal and hopefully by this weekend.
