kareemwaheed
Compiling a library
Sun Sep 29, 2019 1:54 pm
Hi, sorry for this Noob question
but i have this library
https://github.com/wrobell/librpims5x
i need to use it to get readings from the sensor but i'm struggle in using i'm could any one give me an idea with steps how to work with these libraries as i only used python on rasbian and linux overall
kareemwaheed
Re: Compiling a library
Sun Sep 29, 2019 2:43 pm
could anyone help
DirkS
Sun Sep 29, 2019 2:50 pm
could anyone help
It's the weekend and almost everyone here is a volunteer.
You really should wait at least a day before bumping...
B.Goode
Sun Sep 29, 2019 5:54 pm
From the documentation you cited:
The librpims5x project provides C library (with Python 3 bindings) for
various pressure sensors produced by Measurement Specialties
So if you want to use Python, you can.
and
The interface is pretty straightforward, see examples directory.
In the examples directory is a file rpims5x-read.py
That python script has about 12 active lines that demonstrate how to read and display the temperature and pressure from your sensor.
What else do you need to know?
But note that the library in that GitHub repository has not been updated for many years. That might mean it is very stable and reliable, or maybe it has been abandoned...
fbe
Sun Sep 29, 2019 7:20 pm
I would also recommend to search for a more actively maintained library
In ibrpims5x/rpims5x/glue.py I found:
class Sensor(object):
    Pressure sensor communication interface.
    def __init__(self):
        Create pressure sensor communication interface.
        self._lib = ct.CDLL('librpims5x.so.0')
        self._lib.rpims5x_init()
        self._p_value = ct.c_ushort()
        self._t_value = ct.c_ushort()
I don't know much about Python but I guess you need to build and install librpims5x.so.0 first to use the python library.
In librpims5x/src/rpims5x.c you could add
#include <unistd.h>
at the beginning to avoid compiler warnings about implicite function declarations and you could add a return statement to the rpims5x_read_avg function (just compare with the rpims5x_read).
You must change the line
#define BCM2708_PERI_BASE  0x20000000
if you want to use the library with Raspberry Pi3 or later... Otherwise it will crash when running. See https://www.raspberrypi.org/documentati ... dresses.md
You can compile and install the library with
gcc -c -Wall rpims5x.c -o rpims5x.o
gcc -shared -Wall rpims5x.o -o rpims5x.so.0
sudo install -m644 -oroot -groot rpims5x.so.0 /usr/local/lib
sudo ldconfig
If you want to write C programs, install the header
sudo install -m644 -oroot -groot rpims5x.h /usr/local/include
I can't help you with the python installation.
kareemwaheed
Mon Sep 30, 2019 8:27 am
Thank you all, i found a solution using Arduino nano then i'll connect it with Rpi via USB
