rotem.shavit
LTE
Mon Sep 23, 2019 11:54 am
HI,
I am new with rasberrypi and I am looking for a way to transmit a receive data with my rp4 using LTE.
It will be really helpful if someone could give me the right hardware and guides for them.
THANK YOU!
RattusRattus
Re: LTE
Mon Sep 23, 2019 2:07 pm
the first hit I got on google for "lte modem raspberry pi" is this
https://filippobuletto.github.io/home-router-lte/
This looks like a walk though for what you would need and how to do it
BR
/Andy
rotem.shavit
Re: LTE
Thu Sep 26, 2019 10:56 am
OK I will look into it. Thank you!
bjtheone
Re: LTE
Thu Sep 26, 2019 3:05 pm
You might also want to clarify your use case. Do you need temporary or permanent LTE connectivity, and is this "in the field" or in a static office like location.
For example, a Pi happily connects to a cellphone WiFi hotspot. This is likely the quickest and simplest solution. Next up would be LTE hotspot boxes.
For a static environment I would look at LTE modems, which most providers should have.
