I'm having a similar issue -
I was doing an RFID project and was using code based on this:
https://pimylifeup.com/raspberry-pi-rfid-rc522/
I got everything working, but I also need to use some i2c devices, for which I was hoping to use Sparkfun's QWIIC hat:
https://www.sparkfun.com/products/14459
My problem is that pin22 isn't one of the ones exposed by the hat, which the code as written needs for the reset pin. I thought I could just move reset to pin 26 (GPIO 7) and change it in the code:
I changed this:
if pin_rst == -1:
if pin_mode == 11:
pin_rst = 15
else:
pin_rst = 22
to this:
if pin_rst == -1:
if pin_mode == 11:
pin_rst = 15
else:
pin_rst = 26
but.. It's not working at all now.
Anyone know of another reason switching pins would have failed here? I can't help but think it's got something to do with the pinmode here, and I am ALSO supposed to edit the 15, but I can't find anything that correlates the 22 to the 15 in the pinout (ie: pin22 says it's GPIO25, so I could see if the 15 was a 25 in the sample code, I'd have to change it to 7, since pin26 is GPIO7, but can find no such correlation)
I kind of just expected this to work and Im confused!!
Thanks in advance!!
