Pilaced
Can you turn off the pi 4 pwr and Ethernet lights?
Wed Sep 18, 2019 12:16 pm
You can’t on the pi 3 right?
jahboater
Re: Can you turn off the pi 4 pwr and Ethernet lights?
Wed Sep 18, 2019 12:40 pm
I turn the power led off by adding this to /etc/crontab
@reboot root echo 0 > /sys/class/leds/led1/brightness
works on the Pi3 and the Pi4.
There must be a better way .....
trejan
Wed Sep 18, 2019 12:52 pm
No known way of turning off the Pi 4 Ethernet socket LEDs. The LEDs are wired to the Broadcom Ethernet PHY and there is no public documentation on it AFAIK. The config.txt options to turn off the LED is only for the 3B+ and the utility is for the older Pi boards.
stuart72
Sat Dec 21, 2019 7:21 pm
have you seen https://www.raspberrypi.org/forums/view ... p?t=252057 which contains a link to https://github.com/raspberrypi/linux/co ... a8575ee06b which appears to be the code that we need to change to disable the Ethernet LED on a Pi4?
kokosmolch
Thu Aug 27, 2020 6:59 pm
adding these lines to the /boot/config.txt works like a charm for me on a RPi 4 (PI OS 2020-08-20)
#disable ACT and PWR LEDs
dtparam=act_led_trigger=none
dtparam=pwr_led_trigger=none
#disable ethernet port LEDs
dtparam=eth0_led=4
dtparam=eth1_led=4
Cheers
djace
Thu Sep 10, 2020 10:31 am
this is not working for me on RPi4
jahboater
Thu Sep 10, 2020 1:37 pm
This works for me:
[pi4]
# Disable the PWR LED
dtparam=pwr_led_activelow=off
# Disable the Activity LED
dtparam=act_led_activelow=off
# Disable ethernet port LEDs
dtparam=eth_led0=4
dtparam=eth_led1=4
Pi4 8GB running PIOS64 Lite
ejolson
Thu Sep 10, 2020 3:27 pm
This works for me:
[pi4]
dtparam=eth_led0=4
dtparam=eth_led1=4
Once you do this is there anyway to turn the lights on and off programmatically through the /sys interface?
jahboater
Fri Sep 11, 2020 12:41 am
Sorry, never tried to, hopefully someone else knows.
Libin
Tue Oct 13, 2020 2:06 pm
Note that you must add these lines under the tag [pi4]. If you just add these in the end of the file (my config shows the last tag is [all]), it won't work. My rasp version is 4B.
basmeyer
Thu Oct 29, 2020 11:24 am
Thanks jahboater,
That worked out great!
After adding this to /boot/config.txt and rebooting the Pi it takes a little while before they go out but in a while all nice and dark (with only the green LED of the soundboard but that is OK). No more upknockcious lights, especially the ethernet ones.
lamba92
Sun Nov 08, 2020 1:56 am
Any solution for Ubuntu Server as OS? I own a Pi4 and a Pi2 and for both none of the above solutions works. Btw Ubuntu 20.04.
timg236
Sun Nov 08, 2020 2:27 pm
Not a /sys interface but mdiotool https://github.com/PieVo/mdio-tool can be used to poke the MDIO interface directly. The following commands will turn off the LEDs, if you look at the DTBs + Ethernet MAC driver then the other values for link speed / always on are should be the there
# Select expansion register 4
mdiotool w eth0 0x17 0xf04
# Forced off LED2 7:3 0x4 LED1 3:0 0x4
mdiotool w eth0 0x15 0x044
ejolson
Sun Nov 08, 2020 3:20 pm
That looks like it could be interesting to show certain kinds of status conditions. Thanks for the follow up.
trejan
Sun Nov 08, 2020 3:26 pm
Blink the IP address at startup?
Return to “Beginners”
