Bope
Soldering
Sun Sep 15, 2019 8:11 pm
I got the hang of soldering a single wire in the hole in the board. How do you then connect two or more wires that won’t all fit in a single hole in the board?
neilgl
Re: Soldering
Sun Sep 15, 2019 8:15 pm
Maybe solder three wires into a Y shape, put the lower single wire into the hole.
Bope
Re: Soldering
Sun Sep 15, 2019 10:03 pm
Let me try to better clarify. I have a perforated board and say I want to solder an LED to the board. I can easily solder the two poles of the LED onto the board. Now I need to attach a pos and ground to the LED. What I did was bend the wires coming through the bottom of the board so they were touching and soldered them. It was definitely not neat. I figured there is supposed to be a better way.
davidcoton
Re: Soldering
Sun Sep 15, 2019 10:55 pm
AIUI that's how boards with a separate pad for each hole should be used -- either use the ends of the component/wire or a separate piece of hookup wire.
Douglas6
Re: Soldering
Sun Sep 15, 2019 11:14 pm
You can connect pads on a perfboard with insulated wire (two pads), or uninsulated wire (multiple pads) flat against the bottom side of the perf. I like to use the severed leads of a resistor, LED, etc. With a little practice, it can be very neat. Or, you can create solder bridges between adjacent pads with a little more practice (and, preferably, a temperature controlled iron.)
Or you can use perfboards that already have pads connected by traces on the board itself. I love the 'perma-proto' boards from Adafruit. High quality, gold-plated, and reusable with a little care. https://www.adafruit.com/product/1609
Imperf3kt
Re: Soldering
Sun Sep 15, 2019 11:25 pm
Or you can use solder to bridge two holes next to each other.
Solder your LED in, solder a wire to the hole either side of the LEDs legs, then melt some solder between to join the hole the wire is soldered to, with the hole the LED is soldered to.
See some replies here for a detailed example.
https://electronics.stackexchange.com/q ... versal-pcb
55:55:44:44:4C
52:4C:52:42:41
LTolledo
Re: Soldering
Sun Sep 15, 2019 11:38 pm
picture posted for soldering reference only:
enamel coated wire was used in this project
Some people be like:
Douglas6
Re: Soldering
Mon Sep 16, 2019 12:03 am
Is that your own work? Artful. A lost art, I fear.
LTolledo
Re: Soldering
Mon Sep 16, 2019 12:17 am
yes that's mine... and below was the earlier version of that, using cut ribbon cables and resistor lead clippings (not doing this method anymore... I prefer the method I used in the first image)
for the @OP please select your preferred method based on example images above...
have fun! I sure did! :D
LTolledo
Re: Soldering
Mon Sep 16, 2019 12:51 am
...and below may be a bit "extreme" for the OP but I'll post it anyway as soldering reference:
its a DIY arduino nano...
emulate (soldering style) at your own risk :mrgreen:
Re: Soldering
Mon Sep 16, 2019 5:12 am
Nice work. :)
Unreadable squiggle
LTolledo
Re: Soldering
Mon Sep 16, 2019 9:35 am
rpdom wrote:Nice work.
Thanks! :D
I can post more reference images (non-arduino types) if the OP request.... ;)
gordon77
Re: Soldering
Mon Sep 16, 2019 9:41 am
Try some board like this https://www.amazon.co.uk/sheets-board-p ... B07CQ63VZH
You can cut the copper tracks, with a proper tool or a drill, as required. And cut the board to required size.
neilgl
Re: Soldering
Mon Sep 16, 2019 10:02 am
I always use veroboard but I like those delicate examples.
Bope
Re: Soldering
Mon Sep 16, 2019 11:41 am
Thank you for the information. I like the idea of using the pin cutoffs. I tried making a bridge across two holes but it seemed as soon as I took the iron away the solder wicked back to the holes like the board did not want to be wetted. Those wiring jobs that were posted are pretty impressive. With the bare wire don't you worry about them getting bumped and shorting especially where they cross? This is the terminal block/breakout board I was using https://www.amazon.com/gp/product/B01M2 ... UTF8&psc=1. I wired in 2 LEDs and 4 transistors. Last night I finally tested every thing and it all works for now.
mahjongg
Re: Soldering
Mon Sep 16, 2019 11:46 am
The "bare wires" are not actually bare, they are covered with an insulated layer of lacquer (enameled wire).
If you look at the windings of a transformer, these are normally also winded with lacquered copper wire.
If you heat the end of such a wire enough the lacquer will burn off, making it a convenient isolator, as you don't have to strip off the isolation.
LTolledo
Re: Soldering
Mon Sep 16, 2019 12:57 pm
Thanks @mahjongg for backing me up :D
@OP if you prefer to transfer your breadboard circuit to a soldered circuit you may want to try something like this:
my first soldering project in a very long time was made in this type of "proto board" before moving on to the generic proto boards.
here it is below:
do note that its not as good as the first image I posted ;)
drgeoff
Re: Soldering
Mon Sep 16, 2019 1:02 pm
Many years ago in my job I used solderable enamel wire - a reddy-pink colour - for thousands of connections on prototype circuits, burning off the enamel in solder on the iron tip. More recently I heard that the fumes from that are carcinogenic and such work should be done in the proper environment.
mahjongg
Re: Soldering
Mon Sep 16, 2019 4:50 pm
If the copper of the multi-core wire is quite thin, you can twist the cores together, and try if they fit in the single hole, if it gets too thick you can try to cut away half the threads of the multi-core wire, then wrap the remaining ones together and apply solder to them, so that the loose threads are fixed with solder, and then try if you can push the wrapped part through the solder hole.
and yes, burned lacquer vapors can be bad for your health. but then what isn't bad for your health these days, is burning incense not (almost) the same thing, and what about the flux fumes when soldering with modern resin cored solder, which also has a similar substance inside, you should also not breath solder fumes, not because there is lead in those fumes, there isn't, but because you are burning resin/flux.
LTolledo
Re: Soldering
Mon Sep 16, 2019 10:30 pm
might be wondering what tools I used for the soldering projects I did?
nothing fancy, most were bought from the dollar store, the rest from online stores.
the most expensive in the lot is the magnifying lens headset (whatever you call this), at about US$20 from amazon.
Bope
Re: Soldering
Tue Sep 17, 2019 1:47 pm
What gauge wire do you like to use to trace circuits? Does the enamel burn off when you are soldering or do you need to burn it off prior to soldering?
LTolledo
Re: Soldering
Tue Sep 17, 2019 2:53 pm
Bope wrote: What gauge wire do you like to use to trace circuits? Does the enamel burn off when you are soldering or do you need to burn it off prior to soldering?
in the first image that I posted, used (an mainly for my general use) 0.29mm diameter polyurethane coated copper wire
on the DIYduino-nano, I used 0.16mm diameter polyurethane coated copper wire.
I can buy those in 20meter lengths.... quite long enough for such small pcb tracework.
usually I burn off a bit (immerse in hot solder on the iron, not heated iron only), thereby coating the "burned" part with solder, then trimming the "tinned" part to about 1.0 to 1.5mm, then actual solder to board.
attack the exposed part (usually the cut-off/end portion) and let the melted solder burn out the coating.
for making a soldering point within the wire length (first image, bottom right), you need to score/scratch a bit of the coating to expose a bit of the bare wire inside and attack from there.
and do make sure you have some sort of ventilation to suck out the fumes away from you.
parts placement and board wire-trace "crude prototyping" was done using excel and/or libreoffice calc (its what I have and serves its purpose)
...so I have a guide during the actual soldering...
