Sulforaphane
Best way to format a new drive.
Sat Sep 14, 2019 10:11 am
Hello.
I've recently had a bad experience formatting a newly acquired drive to EXT4 on Windows.
Therefore I am curious to what the best, most reliable and safest way of formatting a drive on Raspberry Pi to EXT4?
Thanks in advance!
Re: Best way to format a new drive.
Sat Sep 14, 2019 10:28 am
Use gparted.
This is a doctor free zone.
graysky
Sat Sep 14, 2019 10:54 am
Never use a Linux native port on Windows for something like formatting a disk. What is wrong with using the provided
mkfs.ext4
command? Just TRIPLE check you are applying it to the correct partition. If you haven't yet partitioned, use
fdisk
or
gdisk
and observe the same warning.
To help:
https://wiki.archlinux.org/index.php/Fi ... ile_system
https://wiki.archlinux.org/index.php/Partitioning
Sulforaphane
Sat Sep 14, 2019 4:27 pm
mkfs.ext4
fdisk
or
gdisk
To help:
After having formated it says with sudo fdisk -l:
/dev/sda1 2048 3906961407 3906959360 1,8T Microsoft basic data
Sulforaphane
Sat Sep 14, 2019 4:29 pm
Use gparted.
When formatting it says it has 1 mb unallocated space, that I don't seem to be able to format with gparted. Any way to do this?
Sat Sep 14, 2019 6:23 pm
Don't worry about it. In the grand scheme of things 1MB is a drop in the ocean.
graysky
Sat Sep 14, 2019 9:25 pm
I assume you have not yet copied any data to the drive... you need to change the partition type from within fdisk (ext4 is type 'linux' or something similar as I recall). Without seeing the partition layout, I will assume the 1MB of unallocated space is to keep the partition aligned. It's been too long since I needed to partition a drive.
As a general practice, do not invoke commands with sudo unless you really need to ...
Return to “Beginners”
