Hello.
I've recently had a bad experience formatting a newly acquired drive to EXT4 on Windows.
Therefore I am curious to what the best, most reliable and safest way of formatting a drive on Raspberry Pi to EXT4?
Thanks in advance!
mkfs.ext4Code: Select all
fdiskCode: Select all
gdiskAfter having formated it says with sudo fdisk -l:graysky wrote: ↑Sat Sep 14, 2019 10:54 amNever use a Linux native port on Windows for something like formatting a disk. What is wrong with using the providedcommand? Just TRIPLE check you are applying it to the correct partition. If you haven't yet partitioned, useCode: Select all
mkfs.ext4orCode: Select all
fdiskand observe the same warning.Code: Select all
gdisk
To help:
https://wiki.archlinux.org/index.php/Fi ... ile_system
https://wiki.archlinux.org/index.php/Partitioning
When formatting it says it has 1 mb unallocated space, that I don't seem to be able to format with gparted. Any way to do this?
I assume you have not yet copied any data to the drive... you need to change the partition type from within fdisk (ext4 is type 'linux' or something similar as I recall). Without seeing the partition layout, I will assume the 1MB of unallocated space is to keep the partition aligned. It's been too long since I needed to partition a drive.Sulforaphane wrote: ↑Sat Sep 14, 2019 4:27 pmAfter having formated it says with sudo fdisk -l:
/dev/sda1 2048 3906961407 3906959360 1,8T Microsoft basic data
