If someone can help heres my main files:-
my entry in 'sudo nano /etc/samba/smb.conf'
#======================= Global Settings =======================
[global]
workgroup = WORKGROUP
wins support = yes
#### Debugging/Accounting ####
log file = /var/log/samba/log.%m
max log size = 1000
logging = file
panic action = /usr/share/samba/panic-action %d
####### Authentication #######
server role = standalone server
obey pam restrictions = yes
unix password sync = yes
pam password change = yes
########## Domains ############
############ Misc ############
usershare allow guests = yes
####### Share Definitions############
[homes]
comment = Home Directories
browseable = yes
read only = no
create mask = 0775
directory mask = 0775
valid users = %S
[printers]
comment = All Printers
browseable = no
path = /var/spool/samba
printable = yes
guest ok = no
read only = yes
create mask = 0700
[CCTV_In]
comment = Incoming File From CCTV Camerass
path = /home/pi/CCTV_In ## added for 4TB HDD
writeable = Yes
create mask = 0777
directory mask = 0777
browseable = Yes
public = yes
guest ok = yes
[print$]
comment = Printer Drivers
path = /var/lib/samba/printers
browseable = yes
read only = yes
guest ok = no
Entry in /etc/fstab/
proc /proc proc defaults 0 0
/dev/mmcblk0p6 /boot vfat defaults 0 2
/dev/mmcblk0p7 / ext4 defaults,noatime 0 1
/dev/sda1 /home/pi/CCTV_In ntfs-3g defaults 0 0
sudo blkid
/dev/mmcblk0p1: LABEL_FATBOOT="RECOVERY" LABEL="RECOVERY" UUID="90E6-4AE3" TYPE="vfat" PARTUUID="0005231f-01"
/dev/mmcblk0p5: LABEL="SETTINGS" UUID="7ae383d9-d8c7-4cc1-844a-930d11d80aab" TYPE="ext4" PARTUUID="0005231f-05"
/dev/mmcblk0p6: LABEL_FATBOOT="boot" LABEL="boot" UUID="1454-1ACE" TYPE="vfat" PARTUUID="0005231f-06"
/dev/mmcblk0p7: LABEL="root" UUID="08ed55eb-a878-4b2a-b591-c7d46c4e3223" TYPE="ext4" PARTUUID="0005231f-07"
/dev/sda1: LABEL="CCTV" UUID="5E4224413DFC90AF" TYPE="ntfs" PTTYPE="dos" PARTLABEL="CCTV_In" PARTUUID="e6f57426-bfa1-4dee-b9e2-456699b0a57e"
/dev/mmcblk0: PTUUID="0005231f" PTTYPE="dos"
I've googled until my fingers hurt and tried looking back at previous notes I made, to no avail.
I know it's a basic mistake somewhere, my external HDD is definately mounted where it should be, but still?
Any help please?
