Birdybird
Creatief cron job
Tue Sep 10, 2019 12:16 pm
I want to spindown my usbdisk with command:
5 * * * * sudo sdparm
--command=stop /dev/sda1
Via cronjob -e
(Username pi)
It does not work. When i normally give the command it works.
I restarted cron but nothing happens in 5 minuten.
Please help
pcmanbob
Re: Creatief cron job
Tue Sep 10, 2019 1:05 pm
Hi.
Does the command work if you try it at the command line ?
scruss
Tue Sep 10, 2019 1:44 pm
A crontab line starting with
5 * * * *
runs five minutes after the hour (so 00:05, 01:05, 02:05, …). If you want it to be spun down every five minutes, use:
*/5 * * * *
There may be a way of telling the drive (using sdparm/hdparm) to spin down after X minutes idle rather than forcing it off every five minutes regardless of whether it's busy.
Pronouns: he/him
Birdybird
Tue Sep 10, 2019 1:59 pm
i tried this command now but it still does not work.
*/5 * * * * sudo sdparm --command=stop /dev/sda1
please help
RaTTuS
Contact: Twitter YouTube
Tue Sep 10, 2019 2:29 pm
please help
don't use sudo in cron
use
sudo crontab -e
to make a system cron file
and put the full paths to everything in it
i.e.
*/5 * * * * /sbin/sdparm --command=stop /dev/sda1
or whereever it lives
Covfefe
Birdybird
Re: Create cron job
Tue Sep 10, 2019 2:48 pm
It works. Great thank you.
