Not able to share files to a portable drive on my Raspberry Pi.
Posted: Mon Sep 09, 2019 12:21 pm
by Sulforaphane
I am not able to transfer files from my windows machine to a portable drive connected to my Raspberry Pi on the network through Samba. I am however able to view and read them.
The drive is mounted to /disks/ and has following permissions:
drwxrwxrwx 1 root root 131072 Jan  1  1970 DRIVENAME
Anyone know what's up?
Re: Not able to share files to a portable drive on my Raspberry Pi.
Posted: Mon Sep 09, 2019 12:35 pm
by topguy
See what "mount" reports, also look at the content of the directory ?
Posted: Mon Sep 09, 2019 12:36 pm
by Sulforaphane
What is the command for that?
Posted: Mon Sep 09, 2019 1:04 pm
by topguy
mount
and...
ls -al /disks/DRIVENAME
Posted: Mon Sep 09, 2019 1:33 pm
by Sulforaphane
mount
and...
Oh! Here is the mount.
/dev/sda3 on /disks/DRIVENAME type fuseblk (rw,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096)
Inside the drive, everything is pretty much listed as "root" except:
drwxr-xr-x 4 pi   pi     4096 Sep  8 19:09  ..
Posted: Mon Sep 09, 2019 9:00 pm
by Sulforaphane
Bump
Posted: Tue Sep 10, 2019 5:47 am
by Sulforaphane
Update:
Apparently it's not a matter of permissions, as I am able to transfer small files.
Only big files give me an issue. I've done some digging, and it seems to be how Debian handles ExFAT drives and allocation.
The drive is ExFAT so I can use it on a Windows device also, but do any of you know a solution to this problem?
Posted: Tue Sep 10, 2019 5:51 am
by rpdom
Reformat it as NTFS and install ntfs3g on the Pi. It won't be fast, but it will work.
Posted: Tue Sep 10, 2019 7:09 am
by Sulforaphane
Is there any way to make ExFAT work with transferring large files cross-platform?
Posted: Tue Sep 10, 2019 9:37 am
by topguy
And by large files you mean 4GB+ size files ??
Posted: Tue Sep 10, 2019 5:53 pm
by Sulforaphane
Also 2 GB
Posted: Tue Sep 10, 2019 7:50 pm
by Andyroo
exFat should not have an issue with files larger the 4Gb, Fat32 yes but not exFat.
FAT32 tops out with files at 4 GB in size and hard drives that are 8 TB or less.
ExFat is silly with 16EB files and 128PB volumes :roll:
The only box I’ve played with ExFat on (Debian) needed
sudo apt install exfat-utils exfat-fuse
to run - unsure about a Pi...
Posted: Tue Sep 10, 2019 10:30 pm
by Sulforaphane
Running both. Still having an issue. Gotta wonder what is causing the issue...
