update rate of laser range finder
Posted: Tue Sep 03, 2019 6:38 am
by dineshlama
What exactly is update rate of laser range finder and why is it so low? For example i was doing some research on laser range finder on https://www.mantech.co.za/Lightware.aspx site, and i found that update rate of laser range finder i want is only 32 readings per second. Does this means it only calculated range 32 times in one second?
Re: update rate of laser range finder
Posted: Tue Sep 03, 2019 8:25 am
by B.Goode
Maybe ask the distributor: https://www.mantech.co.za/ContactUs.aspx?Branch=JHB
(There is no indication that this device contains or is reliant upon a Raspberry Pi SBC, so maybe this is not an appropriate forum for your question?)
