Cannot write .img to reader for 4GB SDHC in Win32 DiskImager
Posted: Sat Dec 08, 2012 5:07 pm
by cyborg4
Important information listed in
bold.
I have
waited four and a half months for my Pi, and then when it turns up I can't use it! I am using Win32 DiskImager and have
just performed a scandisk on my SDHC card ( that I have
plugged in through a USB SDHC adapter )
via the GUI. I now am
unable to write to the card via Win32 DiskImager or dd for Windows, and yet I
can still write files to the SDHC in Windows Explorer. I am using a Sony SDHC C4 4GB with the product number SF-4B4. ( The official Sony support page for this product is at
http://www.sony.co.uk/support/en/product/sf-4b4 ). Can anyone help? I am using a
Windows 7 32bit OS.
Re: Cannot write .img to reader for 4GB SDHC in Win32 DiskIm
Posted: Sat Dec 08, 2012 5:26 pm
by Burngate
I can't help, because I've never encountered a problem. I've used win32diskimager on both XP and 7 without a problem!
The only thing I have seen, and do so each time, is an error message because it wants the card dismounted. I just ignore that!
Sorry!
Posted: Sat Dec 08, 2012 5:34 pm
by redhawk
If you cannot flash a 4GB+ SD card don't blame the software it's usually non-compliant SDHC card readers that are the problem.
A simple solution would be to upgrade your SD card reader like the ones sold in Poundland.
Richard S.
Posted: Sun Dec 09, 2012 9:19 am
by cyborg4
redhawk wrote:If you cannot flash a 4GB+ SD card don't blame the software it's usually non-compliant SDHC card readers that are the problem.
Richard S.
My card reader works fine! I can still transfer files to and from the card!
Posted: Sun Dec 09, 2012 11:31 am
by Wheel_nut
Cyborg4, You should take Redhawk's advice and try a different SD Card to USB adapter.
Many Laptops have SD Card slots which work when reading and writing using Windows Explorer but are NOT recognised by Win32DiskImager. I use MicroSD cards and find that a SD Card to USB adapter plugged into a USB socket works very reliably.
Posted: Sun Dec 09, 2012 6:59 pm
by cyborg4
Wheel_nut wrote:Cyborg4, You should take Redhawk's advice and try a different SD Card to USB adapter.
Thanks, but I
am using a USB adaptor, and not a built-in reader. I have used this on other computers, although just to transfer files, without a problem. Are you saying it is that type of reader that doesn't work? Or should mine work fine?
P.S. DD for Windows doesn't work on it either!
Posted: Sun Dec 09, 2012 7:22 pm
by Wheel_nut
Yes, Win32DiskImager seems to be fussy about SD Card adapters. Some work and some don't.
In Win32DiskImager, after you select the source Image file using the Browse button, then click on the destination drive button at the RHS of the panel, it should give you a choice of any available drives to write to. If nothing shows up, try a different adapter and/or SD Card.
Posted: Thu Dec 13, 2012 6:46 pm
by cyborg4
Wheel_nut wrote:Yes, Win32DiskImager seems to be fussy about SD Card adapters. Some work and some don't.
It does give me the device, but then it just gives me an error when I press 'Write'!
Posted: Thu Dec 13, 2012 7:50 pm
by Wheel_nut
What Windows Version are you using?
XP+SP3? Vista+SP2? Windows 7? or Windows 8?
Is it 32Bit or 64Bit?
Posted: Thu Dec 13, 2012 8:01 pm
by Dweeber
I use MicroSDHC cards with SDCard adapters. I just had a brand new card that had problems writting.... this is out of more than 8 other cards that I use. Played around with it for a couple days.... opened another brand new card and it worked fine.
Not all cards work for writing images... and it is sometimes not the same thing as using it for windows.
I had another one which I could write to all day long, but could never read from it to make a backup. Worked great in the Raspberry.. but I was never able to back up the disk to an image. Would get to around 3.4gb and then freeze with a semaphore error.... Stuff happens.
If you can't get that card to work, try another.
BTW I tried a number of solutions to get both of these card issues to work, Win32diskimager (several different versions), DD for Windows, Roadkil's Disk Image (Dangerous Tool), Linux.... eventually I tried it on another box and had the same exact issues...tried a new card... no problems
Posted: Thu Dec 13, 2012 10:43 pm
by SiriusHardware
cyborg4 wrote:Important information listed in
bold.
I have
Windows 7 32bit OS.
Hi CB4 - sorry to even have to suggest this, but is it possible that the sliding 'lock' switch on the card has somehow moved to the 'locked' position since you did your various operations on the card in Windows?
Working in Windows, try reformatting the card: With the card in the reader and the reader in the computer, use a file browser / navigator (such as Windows Explorer) to look at the drives on your system. Right-click on the icon for the drive/reader with the card in it, and select 'Format'. If offered the choice of 'Quick Format', reject that choice / uncheck that box so that Windows will fully reformat the card.
Alternatively, if you have access to a digital camera which can use SDHC cards, put the card in the camera and use the camera's 'format card' feature to format it - it will probably create some unwanted folders (such as 'DCIM') on the card, but don't worry about that - once Win32DiskImager is able to 'see' the card it will overwrite everything on it anyway.
Either way, see if win32 DiskImager is now able to write to the card. Incidentally: Win32DiskImager nearly always comes up with an error message about the media being 'in use' when first run. Just click OK to make that go away, and then carry on.
Posted: Thu Dec 13, 2012 11:09 pm
by NigeH
I can recommend using berryboot.
Simple as you put one file on the card from windows and boot the pi from that - select what you want in the menus and it will build the card for you on the pi.
Posted: Thu Dec 13, 2012 11:45 pm
by itsonlyme
For those having problems. The alternative I use is Roadkills Disk Imager from
http://www.roadkil.net/program.php/P12/Disk%20Image
I find it works most of the time. On the occasions it does not I find that using the "restore device for formatting" button on the Raspbmc installer fixes the card without reformatting. In fact reformatting seems to cause problems.
Malcolm
Posted: Fri Dec 14, 2012 1:19 am
by Dweeber
Good tool... however
BE VERY CAREFUL when using it. Unlike Win32diskimager which defaults only to inserted removable drives, Roadkil defaults to Drive C which can make for a very bad day if you are not paying attention. It also references to drive letters and then Physical Drives which might confuse some.
Use with care.
Posted: Fri Dec 14, 2012 9:05 am
by itsonlyme
I echo Dweebers words of caution. Check everything before you press "start".
Normally you would be using the Physical Drives which are the numbered drives in the bottom part of the list.
Malcolm
Posted: Fri Dec 14, 2012 9:15 am
by Rushy
I had the same issue at one point using an old Vista machine, all i did to solve the issue was do a quick format on the SD card and the Disk Imager would write the img file ok.
Posted: Sat Dec 15, 2012 4:09 pm
by cyborg4
Wheel_nut wrote:What Windows Version are you using?
Sorry about long time replying - getting a lot of spam users on my social network!
Win7 32bit is the OS.
Posted: Sat Dec 15, 2012 4:15 pm
by cyborg4
No, the lock switch definetely isn't on because I can format it. However, I just reformatted and ran Win32 DiskImager and it gives me an Error 3 : The system cannot find the path specified. I am pointing it to a .IMG on a network drive, could this be to do with it?
Thanks so much for your prompt responses, everyone!
Posted: Sat Dec 15, 2012 4:31 pm
by Jim JKla
There is just the posibility you have a flaky SD card I've used a number of readers cards of various sizes win32DiskImager dd and I have had some work with one and not another.
My most relyable has been a poundland adaptor thats done everything from a 1g R Razor image through 2 and 4g upto a 32 micro SD in an adaptor SD card.
All have worked.
Posted: Sat Dec 15, 2012 4:32 pm
by properphatboy
Just to add my 2p, I'd had no probs with any of my SD cards until I came to reformat one last night and none of the windows disk management stuff would touch it!
So I used HP's SD card format tool (it's not even an HP reader or card) and it worked perfectly. There are ones by other manufacturers too.
Just another tool that's worth a try.
And if still no joy, I picked up a couple of 4GB SD cards from Tesco fro £3.50 each the other day, which wasn't bad for having them to use straight away.
Posted: Tue Dec 18, 2012 4:02 pm
by cyborg4
Posted: Tue Dec 18, 2012 4:20 pm
by Wheel_nut
Well done! I hope you enjoy your Pi as much as the rest of us do.
Posted: Mon Apr 08, 2013 8:04 am
by NathanBookham
Windows has always been funny about network drives. I don't know why, but it doesn't treat it as a storage device, but as some strange proprietary device. Also, your network probably isn't fast enough to access a 2GB image file, unless you have CAT6 run around your house (very expensive
Glad you got it working! Happy Piing!
