auDioonly
Can I set video mode to av on Pi model 1
Thu Aug 29, 2019 6:03 pm
Hello
I am running pCP and LMS with jivelite on a Pi model 1. It works fine in HDMI mode and output but I would like to try a 4 inch av screen.
I can read config.txt on the laptop. What would I need to change to output av and I am unsure of editing it. Everything begins with a #, what does it mean.
auDioonly
itimpi
Re: Can I set video mode to av on Pi model 1
Thu Aug 29, 2019 6:10 pm
Lines beginning with a hash are comments and therefore do not do anything. You need to remove the hash to make the line active.
auDioonly
Thu Aug 29, 2019 7:19 pm
Thanks for that, is that the same as uncommenting.
drgeoff
Thu Aug 29, 2019 11:08 pm
RPis prior to RPi4B normally automatically output to the AV jack if an HDMI display is not plugged in at boot time.
auDioonly
Fri Aug 30, 2019 5:18 pm
I will try that.
auDioonly
Fri Aug 30, 2019 5:54 pm
That didn't work. Fresh copy of both pCP then moode with no HDMI connection just av and nothing. The 7" monitor can cycle through vga, hdmi and av but nothing came over av.
drgeoff
Fri Aug 30, 2019 9:04 pm
I normally run my piCorePlayer + LMS on a headless RPiB+ (yes I do mean B+, not 3B+). I've just now connected its AV jack to my TV and it works.
auDioonly
Mon Sep 02, 2019 10:19 am
I have just found a TV with an AV input so I will connect the Pi 1 up and try again. That will eliminate my AV monitors and also the cable.
auDioonly
Mon Sep 02, 2019 5:30 pm
That worked perfectly, AV from a Pi model 1. The problem was the AV lead was open circuit so it does give AV output as you said.
The next thing is to get AV from my Pi 3B+.
aDioonly
drgeoff
Mon Sep 02, 2019 5:33 pm
aDioonly
Make sure you have a suitable cable. See https://www.raspberrypi.org/forums/view ... 22#p653422
auDioonly
Mon Sep 02, 2019 7:29 pm
I have a 3.5mm AV lead with 3 connections on the jack plug that does work on the Pi 1. Does the Pi 3B+ also default to AV and is it the same cable.
drgeoff
Mon Sep 02, 2019 9:15 pm
Yes and yes.
Tue Sep 03, 2019 7:47 am
Well, the Pi 1 didn't have an AV jack, just an audio jack and separate video Phono/RCS connection.
The Pi 1B+ and A+ had the combined AV jack that all Pis (except the Zero) have had since.
The same cables will work in all of them though, but the Pi 1A/B won't have video on the cable.
Unreadable squiggle
