raspberrypifreak
firmware update for pi zero w?
Sat Aug 24, 2019 5:41 am
Does it exist? :D
Re: firmware update for pi zero w?
Sat Aug 24, 2019 5:52 am
Which firmware were you thinking of, and why do you ask about an upgrade?
Most of what you might call "firmware" is stored in the boot partition of the SD card and will get updated along with the kernel and bootloader when you do sudo apt update and sudo apt upgrade.
Firmware for things like the WiFi chip are in other packages that will also get updated via this method.
There is no upgradeable firmware store in the main chip, just a small permanent boot ROM. The Pi 4B is the first Pi to have any updatable code stored in the main chip.
LTolledo
Sat Aug 24, 2019 5:54 am
@ OP do you have a RPiZeroW?
Some people be like:
raspberrypifreak
Sat Aug 24, 2019 6:06 am
Yes I do.
raspberrypifreak
Sat Aug 24, 2019 6:08 am
I don't know. I just heard about firmware updates for the pi 4 to keep it cool, so I thought there may be firmware updates for the Pi Zero W that might improve it in some way.
Sat Aug 24, 2019 6:20 am
Any updates of kernel / firmware / packages, if any, are included in the Raspbian Buster Operating System when upgrading:
sudo apt update
sudo apt full-upgrade
sudo teboot
adieu
Asus CS10 Chromebit / HP Envy 4500 Wireless Printer / Raspberry Pi Model 2B v1.1 / RealVNC Software...
davidcoton
Sat Aug 24, 2019 9:27 am
sudo apt update
sudo reboot
FTFY
Signature retired
raspberrypifreak
Sat Aug 24, 2019 10:54 am
Thanks for the replies. Much appreciated! :)
Sat Aug 24, 2019 12:10 pm
sudo reboot
FTFY
But, sudo teboot is better. That one boils the IoT kettle, activates the robot to pour water on the tea-bag then waits five minutes for it to brew before rebooting the Raspberry.
This is a doctor free zone.
thagrol
Sat Aug 24, 2019 3:04 pm
Does it exist? :D
Strictly speaking no.
firmware
noun COMPUTING
permanent software programmed into a read-only memory.
The only firmware in a zero/zeroW(H) is the first stage bootloader built into the SoC. That's only upgradable with a new revision of the SoC and then you'd have to be able to handle the chip replacement...
This space unintentionally left blank.
mahjongg
Sat Aug 24, 2019 4:17 pm
True, the RPI4 is the first PI to actually has re-writable memory, that can contain firmware (boot code).
Earlier RPI's, including the zero, DO NOT HAVE firmware in upgradable permanent memory, they have no permanent memory at all, expect a very small piece ( a few kilo bytes) of boot code that has been "baked in the silicon", and cannot be changed, and a few BYTES of one time programmable PROM with a pre-defined use.
W. H. Heydt
Sat Aug 24, 2019 5:50 pm
A quibble... The updatable firmware for the Pi4B is NOT part of the SoC. It is a separate EEPROM on the PCB.
Sat Aug 24, 2019 5:55 pm
Is it? Which chip is that then? I see a PMIC, SoC, RAM, USB and Ethernet chips on the board.
W. H. Heydt
Sat Aug 24, 2019 5:56 pm
Cooling is not an issue with the PI0/Pi0W. The SoC on those boards is a single CPU core plus the VC4 graphics at a default 1GHz. The Pi4B has 4 far more capable CPU cores at a default 1.5GHz and an upgraded VC6 graphics core. As a result, the Pi4B generates a LOT more heat. Indeed, under any conditions I have ever run a Pi, a Pi4B is the first one I have ever seen even begin to show an overheating warning. (Fortunately, it was easily remedied, even if the remedy *looks* rather ugly. I"m still deciding how I'm going to tackle a permanent, clean, solution. It'd be easy except for a shortage of 5v pins...)
W. H. Heydt
Sat Aug 24, 2019 5:57 pm
Beats me. Perhaps one of the RPT engineers will tell you...or correct me.
hippy
Sat Aug 24, 2019 7:27 pm
AIUI, though I might be misremembering -
The Boot Eeprom is on the rear of the board at the top right with GPIO pins at the top.
The Eeprom for USB is on the front of the board, immediately bottom left of the VLI chip.
The Eeprom for LAN is the chip below that, above the jack socket.
hippy
Sat Aug 24, 2019 7:32 pm
Except that depends on what one means by "firmware". The Boot Loader Code which is held in the Boot Eeprom is not currently updated by an apt or apt-get process though it may be in the future.
