KitchM
Disable DHCP
Fri Aug 23, 2019 4:06 pm
How can I disable DHCP on Raspbian 9 and just use a static Eth0 address?
Re: Disable DHCP
Fri Aug 23, 2019 4:22 pm
Edit /etc/dhcpcd.conf to set a static address for the interface. There are examples in the file.
KitchM
Re: Disable DHCP
Fri Aug 23, 2019 5:18 pm
Thanks, I'll try that again. It didn't work the first time. Somewhere else was the idea to uninstall DHCP.
Andyroo
Re: Disable DHCP
Fri Aug 23, 2019 6:40 pm
Strange though it can be picky if you miss the subnet range off.
The last one I set up was:
# Added 20th June - matches EE Router
interface eth0
static ip_address=192.168.1.10/24
static routers=192.168.1.254
static domain_name_servers=192.168.1.2
The note over matching the router is that I got the EE router to let me change the address on its control screen for a change :lol: :cry: :roll:
I just add this at the start of the file and leave everything else alone. Note my network is IPv4 only.
Re: Disable DHCP
Fri Aug 23, 2019 7:31 pm
You can encourage dhcpcd to completely ignore interfaces then Linux will generate a 169.254.xxx.yyy address for an interface that is UP but doesn't get a DHCP DISCOVERY/OFFER/REQUEST/ACK.
If you add
denyinterfaces eth0
denyinterfaces wlan0
then it really is disabled.
If you set static addresses with DHCPCD you don't need to supply a router address, just leave that one out or set it to the same address as you've set for the interface.
This is a doctor free zone.
