I have connected up a new HDD (info below), but I cannot see it on the network and my CCTV Cameras (obviously) cannot write to it.
I can drill down to it through a putty window and write to it that way, can anyone help me see it through windows 10 by linking it as a network drive?
Thanks.
Here's all the info, if you need anything else please ask.
Output from sudo blkid :-
/dev/mmcblk0: PTUUID="0005231f" PTTYPE="dos"
/dev/mmcblk0p1: LABEL="RECOVERY" UUID="90E6-4AE3" TYPE="vfat" PARTUUID="0005231f-01"
/dev/mmcblk0p5: LABEL="SETTINGS" UUID="7ae383d9-d8c7-4cc1-844a-930d11d80aab" TYPE="ext4" PARTUUID="0005231f-05"
/dev/mmcblk0p6: LABEL="boot" UUID="03FA-9CB4" TYPE="vfat" PARTUUID="0005231f-06"
/dev/mmcblk0p7: LABEL="root" UUID="5532747b-f5d8-419e-a01e-d36acf2d334f" TYPE="ext4" PARTUUID="0005231f-07"
/dev/sda1: UUID="79860ABD06E961A6" TYPE="ntfs" PTTYPE="dos" PARTLABEL="CCTV1" PARTUUID="a085d050-e1a4-4d67-9f0f-7e6ce5c4698e"
Directory created in /mnt:-
pi@raspberrypi:~ $ cd /mnt
pi@raspberrypi:/mnt $ ls
CCTV1
My etc/fstab file as at 23/08/2019:-
proc /proc proc defaults 0 0
/dev/mmcblk0p6 /boot vfat defaults 0 2
/dev/mmcblk0p7 / ext4 defaults,noatime 0 1
# a swapfile is not a swap partition, no line here
# use dphys-swapfile swap[on|off] for that
UUID=79860ABD06E961A6 /mnt/CCTV1 auto defaults,user,nofail 0 2
My /etc/samba/smb.conf file as at 23/08/2019:- (only showing active lines of code)
workgroup = WORKGROUP
wins support = yes
dns proxy = no
log file = /var/log/samba/log.%m
max log size = 1000
panic action = /usr/share/samba/panic-action %d
server role = standalone server
obey pam restrictions = yes
unix password sync = yes
passwd program = /usr/bin/passwd %u
passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n$
map to guest = bad user
; logon script = logon.cmd
; add user script = /usr/sbin/adduser --quiet --disabled-password --gecos "" %u
; add machine script = /usr/sbin/useradd -g machines -c "%u machine account" -$
; add group script = /usr/sbin/addgroup --force-badname %g
; include = /home/samba/etc/smb.conf.%m
; idmap uid = 10000-20000
; idmap gid = 10000-20000
; template shell = /bin/bash
usershare allow guests = yes
[homes]
comment = Home Directories
browseable = yes
read only = no
create mask = 0700
directory mask = 0700
valid users = %S
;[netlogon]
; comment = Network Logon Service
; path = /home/samba/netlogon
; guest ok = yes
; read only = yes
;[profiles]
; comment = Users profiles
; path = /home/samba/profiles
; guest ok = no
; browseable = no
; create mask = 0600
; directory mask = 0700
[printers]
comment = All Printers
browseable = no
path = /var/spool/samba
printable = yes
guest ok = no
read only = yes
create mask = 0700
[print$]
comment = Printer Drivers
path = /var/lib/samba/printers
browseable = yes
read only = yes
guest ok = no
[CCTV1]
comment = external Files
browseable = yes
path = /mnt/CCTV1 ##/mnt/CCTV1 added for 4TB HDD
writeable = Yes
create mask = 0777
directory mask = 0777
browseable = Yes
public = yes
guest ok = yes
I hope that helps somewhat.
Problems with External 4TB HDD
Make the most of your family and friends , your children grow up too quickly and you don't notice yourself ageing, friends dissapearing, moving on. You make plans for your future, but they can all be smashed in an instant, live life and enjoy.
Re: Problems with External 4TB HDD
try adding
under the global part
client max protocol = NT1
Some people be like:
still getting 'the network name cannot be found' when trying to log into 'cctv1'?
Yes, unfortunatelydoubleudee1 wrote: ↑Fri Aug 23, 2019 2:59 pmstill getting 'the network name cannot be found' when trying to log into 'cctv1'?
- DougieLawson
- Contact: Website Twitter
Have you tried mounting the share on Linux just to test it?
mount -t cifs \\\\127.0.0.1\\CCTV1 /media -o user=sambauseridhere,password=sambauserspasswordhere
Have you run sudo testparm to check the syntax and sanity of your samba config?
BTW, I'd create a special mount point sudo mkdir /CCTV1 and change to that from /mnt/CCTV1 for your drive because I use /mnt for all sorts of stuff with USB sticks and SDCards in readers. My system has /srv and /shared where my NAS drive NFS shares are mounted. I've moved /var/www to /srv/www for the apache2, lighttpd and nginx webservers that run on each Raspberry.
I ran the command and this was the reply:-DougieLawson wrote: ↑Fri Aug 23, 2019 3:11 pmHave you tried mounting the share on Linux just to test it?
pi@raspberrypi:~ $ sudo testparm
Load smb config files from /etc/samba/smb.conf
rlimit_max: increasing rlimit_max (1024) to minimum Windows limit (16384)
WARNING: The "syslog" option is deprecated
Processing section "[homes]"
Processing section "[printers]"
Processing section "[print$]"
Processing section "[CCTV1]"
Loaded services file OK.
Server role: ROLE_STANDALONE
Press enter to see a dump of your service definitions
- DougieLawson
That SMB conf stuff looks OK. What happened when you tried to mount it on Linux?
It mounted ok, with no problems, should I unmount and start again?
I can see the raspberry pi from windows explorer and I can also see a folder 'cctv1' inside it.
But when I right click on it and select to map a network drive, I get the error message 'Windows cant find '//Raspberrypi/cctv1', check network or spelling.
So I think it is a neuwork problem somewhere, but I cannot for the life of me find it.
Should those forward slashes be back-slashes? See:
https://www.laptopmag.com/articles/map- ... windows-10
hth
Phil
hth
Phil
- DougieLawson
Linux needs back slashes \\ for SMB mounts. You have to use two back-slashes to get one as they need the backslash escape character for the bash shell. Hence four back slashes at the front of the UNC and two back slashes in the middle.
Hi, I had something similar. I'm a complete novice, but after trying many different solutions, I remembered reading that in Raspian, the CaSe of your text matters. so SAMBA is not the same as samba. I see you used 'CCTV' and then 'cctv'. try using both upper case (or both lower case)
