rpinewsymphony
How to combine two infrared sensor codes for one program?
Mon Aug 19, 2019 2:30 pm
Hello, I am new to python and i would like to run my program based on the two infrared sensor to read two different readings of rpm of the two motor at the same time. Here is the code that we tried to make.
#!/usr/bin/python3
import RPi.GPIO as GPIO
from time import sleep
import time, math
dist_meas = 0.00
dist_meas1 = 0.00
km_per_hour = 0
km_per_hour1 = 0
rpm = 0
rpm1 = 0
elapse = 0
elapse1 = 0
sensor = 24
sensor1 = 27
pulse = 0
pulse2 = 0
start_timer = time.time()
def init_GPIO():					# initialize GPIO
	GPIO.setmode(GPIO.BCM)
	GPIO.setwarnings(False)
	GPIO.setup(sensor,GPIO.IN,GPIO.PUD_UP)
def calculate_elapse(channel):				# callback function
	global pulse, start_timer, elapse
	pulse+=1								# increase pulse by 1 whenever interrupt occurred
	elapse = time.time() - start_timer		# elapse for every 1 complete rotation made!
	start_timer = time.time()				# let current time equals to start_timer
def calculate_speed(7):
	global pulse,elapse,rpm,dist_km,dist_meas,km_per_sec,km_per_hour
	if elapse !=0:							# to avoid DivisionByZero error
		rpm = 1/elapse * 60
		circ_cm = (2*math.pi)*6			# calculate wheel circumference in CM
		dist_km = circ_cm/100000 			# convert cm to km
		km_per_sec = dist_km / elapse		# calculate KM/sec
		km_per_hour = km_per_sec * 3600		# calculate KM/h
		dist_meas = (dist_km*pulse)*1000	# measure distance traverse in meter
		return km_per_hour
def init_interrupt():
	GPIO.add_event_detect(sensor, GPIO.FALLING, callback = calculate_elapse, bouncetime = 20)
def init_GPIO1():					# initialize GPIO
	GPIO.setup(sensor1,GPIO.IN,GPIO.PUD_UP)
def calculate_elapse1(channel):				# callback function
	global pulse1, start_timer, elapse1
	pulse1+=1								# increase pulse by 1 whenever interrupt occurred
	elapse1 = time.time() - start_timer		# elapse for every 1 complete rotation made!
def calculate_speed1(6):
	global pulse1,elapse1,rpm1,dist_km1,dist_meas1,km_per_sec1,km_per_hour1
	if elapse1 !=0:							# to avoid DivisionByZero error
		rpm1 = 1/elapse1 * 60
		circ_cm1 = (2*math.pi)*6			# calculate wheel circumference in CM
		dist_km1 = circ_cm/100000 			# convert cm to km
		km_per_sec1 = dist_km1 / elapse1		# calculate KM/sec
		km_per_hour1 = km_per_sec1 * 3600		# calculate KM/h
		dist_meas1 = (dist_km1*pulse1)*1000	# measure distance traverse in meter
		return km_per_hour1
def init_interrupt1():
	GPIO.add_event_detect(sensor1, GPIO.FALLING, callback = calculate_elapse1, bouncetime = 20)
if __name__ == '__main__':
	init_GPIO()
	init_interrupt()
	while True:
		calculate_speed(6)	# call this function with wheel radius as parameter
  		print('rpm:{0:.0f}-RPM kmh:{1:.0f}-KMH dist_meas:{2:.2f}m pulse:{3}'.format(rpm,km_per_hour,dist_meas,pulse))
sleep(0.1)
	init_GPIO1()
	init_interrupt1()
	while True:
  		print('rpm1:{0:.0f}-RPM kmh1:{1:.0f}-KMH dist_meas1:{2:.2f}m pulse1:{3}'.format(rpm1,km_per_hour1,dist_meas1,pulse1))
sleep(0.1)
B.Goode
Re: How to combine two infrared sensor codes for one program?
Mon Aug 19, 2019 3:26 pm
Welcome to the Raspberry Pi forums.
#!/usr/bin/python3
import time, math
dist_meas = 0.00
dist_meas1 = 0.00
km_per_hour = 0
km_per_hour1 = 0
rpm = 0
rpm1 = 0
elapse = 0
elapse1 = 0
sensor = 24
sensor1 = 27
pulse = 0
pulse2 = 0
		rpm = 1/elapse * 60
		return km_per_hour
		return km_per_hour1
	init_GPIO()
	init_interrupt()
	while True:
sleep(0.1)
	init_GPIO1()
	init_interrupt1()
	while True:
sleep(0.1)
You need to rethink your logic and the corresponding code implementation.
The point of a while True: loop is that it never exits. Because the constant True is always logically True.
So once you get to the first loop -
	while True:
sleep(0.1)
... that's where your code carries on running until externally interrupted.
That is probably not what you intended?
rpinewsymphony
Tue Aug 20, 2019 1:45 am
sorry for late reps...been busy researching how to fix the code but I did not know how until now sir😭😭😭...what should I do?
PhatFil
Tue Aug 20, 2019 2:13 am
currently you have
init first thing
while true
	do first thing
init second thing
while true
	do Second thing
how about something like
init first thing
init second thing
while true
       do first thing
       do second thing
