RPi 4: Booting by shorting GND and GPIO3 (pins 5 and 6) not working
Posted: Fri Aug 16, 2019 8:08 pm
Welcome everyone. I was trying to add power off/on system. At first I wanted to use simple shorting by cables, later I'm going to add either RF of ESP2866 to turn on/off wirelessly. I read, that I should add
to /boot/config.txt. After doing so, shutting down Pi works fine, but I cannot wake it using same method. Only way to boot it up is to unplug and plug again power supply.
Content of my config.txt is:
Am I missing anything to make use of powering on by shorting pins 5 and 6? I also tried to use pins 39 and 40 (GND and GPIO21) by setting
but result was the same.
Regards
P. S. I have "Remote GPIO" set to Disabled in RPi configuration. Is that correct?
dtoverlay=gpio-shutdownContent of my config.txt is:
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=1
hdmi_mode=4
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
dtparam=audio=on
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
[all]
#dtoverlay=vc4-fkms-v3d
# NOOBS Auto-generated Settings:
dtoverlay=gpio-shutdown,gpio_pin=21Regards
