ModernWires
Is it safe to connect the GND pin to the GND of an external USB psu?
Sun Aug 11, 2019 9:57 am
Is it safe to connect the GND pin of the raspberry pi (I'm using the new pi 4b specifically) to the GND of another USB power supply like shown below? I want to turn on and off a mosfet based on the output of a gpio pin. I don't want to use the on board USB or the 5V pin to power the load because I'm afraid of destroying the USB controller or even the entire raspberry pi if I accidentally do something stupid.
pcmanbob
Re: Is it safe to connect the GND pin to the GND of an external USB psu?
Sun Aug 11, 2019 10:00 am
Simple answer YES.
You will need both grounds connected together as you will need both grounds for your circuits to be complete or it wont work.
boyoh
Wed Aug 14, 2019 8:38 am
Yes the , communing the ground connections is ok
But if you want to keep Bothe power supplies
Isolated you could use a Opto Isolator to switch
The signal, this will give total physical isolation
Between power supplies and noise isolation
No need to common the grounds
Regards BoyOh
BoyOh ( Selby, North Yorkshire.UK)
Some Times Right Some Times Wrong
