Page 1 of 2
100 msec timer interrupt, input switch interrupt , display 2 numbers on a hdmi screen
Posted: Wed Aug 07, 2019 8:18 pm
by hkpatnaik
hi all i am new to raspberry. pls help me with coding timer (100 msec) , switch input interrupt
how can i display 2 numbers on the hdmi screen 1'' high and 4'' high ( example 54 on 2 different size)
any help is appreciated
harry P
Re: 100 msec timer interrupt, input switch interrupt , display 2 numbers on a hdmi screen
Posted: Wed Aug 07, 2019 10:30 pm
by neilgl
Is that like a stopwatch/timer sort of thing?
Posted: Thu Aug 08, 2019 2:25 pm
by hkpatnaik
yes it is 100msec ( 0.1sec) timer and certain events run due to the timer.
Also i need a random number generator program
Posted: Thu Aug 08, 2019 3:22 pm
by neilgl
Here is an example of python3 using tk to display a simple GUI program, with large fonts. Is that what you want? GPIO and timer code can be added later, and python has a random number generator.
Run it from a terminal: python3 big.py
# python3 and tk
import tkinter as tk
class Application(tk.Frame):
    def __init__(self, master=None):
        super().__init__(master)
        self.pack()
        self.create_widgets()
    def create_widgets(self):
        self.hi_there = tk.Button(self)
        myfont = ('times', 132, 'bold')
        self.hi_there["text"] = "54 Hello World\n(click me)"
        self.hi_there.config(font = myfont)
        self.hi_there["command"] = self.say_hi
        self.hi_there.pack(side="top")
        newfont = ('Helvetica', 64, 'bold')
        self.quit = tk.Button(self, text="QUIT", fg="red",command=root.destroy)
        self.quit.config(font = newfont)
        self.quit.pack(side="bottom")
    def say_hi(self):
        self.hi_there["text"] = "54 Hello World\n(clicked)"
root = tk.Tk()
app = Application(master=root)
app.mainloop()
Posted: Thu Aug 08, 2019 8:05 pm
by hkpatnaik
I have a RP board running with a monitor on the hdmi port. I also have a SD card with boot program which has NOOBS i believe. so after booting I have a Road scene and there are few tabs in the left hand corner starting with Raspberry etc. I have a key board and mouse.
How do i type in the program u provided? do i go to editor . at present if i go to terminal mode i see a $ prompt
so i know i am asking basic questions like how do i enter the program. do i open The Thonny python IDE???
thanks
hare
Posted: Thu Aug 08, 2019 8:16 pm
by rpdom
Click on the Raspberry to get the program menu. Select the "Programming" option. That will give you a list of various programming tools including Thonny.
Posted: Thu Aug 08, 2019 8:18 pm
by neilgl
In the browser, looking at this forum at my example, Select all, edit copy.
Start a terminal prompt. ( You could do it via Thonny, but not needed.)
Edit a file called big.py like this:
nano big.py
Now edit paste, the code appears on your terminal
Press control-o, control-x to save big.py and exit nano.
Now at the $ prompt, type
python3 big.py
It should start the GUI program.
Let me know how it goes...
Posted: Sat Aug 10, 2019 2:49 pm
by hkpatnaik
Hi neilgl,
Thanks for u r help. I am having trouble with key board. I have changed 3 key boards for If i use the # key on raspberry the display shows British pound sign. I can not see the # sign at all. I have not compiled but changed key boards still i can not type # sign but on my PC it shows # but on RP it shows the british pound sign
thanks again for working with me
hare
Posted: Sat Aug 10, 2019 3:06 pm
by gordon77
Try changing the settings...
choose Preferences > Raspberry Pi Configuration > Localisation > Keyboard, then choose as required
Posted: Sat Aug 10, 2019 3:44 pm
by hkpatnaik
hi neigel,
Thanks, sorry to bother u. I get syntax error
code:select all syntax error at ":"
also syntax error
nano big.py syntax error at big.
pls. help
hare
Posted: Sat Aug 10, 2019 3:56 pm
by gordon77
Heres' a pygame stopwatch
import RPi.GPIO as GPIO
import pygame, sys
import time
from pygame.locals import *
GPIO.setmode(GPIO.BOARD)
GPIO.setwarnings(False)
switch = 11 # pin 11, switch to +3.3v
GPIO.setup(switch,GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
redColor = pygame.Color(255,0,0)
greyColor = pygame.Color(50,50,50)
pygame.init()
font_size = 200
width = font_size * 6
height = font_size
windowSurfaceObj = pygame.display.set_mode((width,height),1,24)
pygame.display.set_caption('STOPWATCH')
fontObj = pygame.font.Font('freesansbold.ttf',font_size)
msg = "00:00:00:000"
msgSurfaceObj = fontObj.render(msg, False,redColor)
msgRectobj = msgSurfaceObj.get_rect()
msgRectobj.topleft =(2,0)
windowSurfaceObj.blit(msgSurfaceObj, msgRectobj)
pygame.display.update()
try:
   while GPIO.input(switch)==0:
      down = 0
   print ("  Ready")
   down = 0
   while True :
      if GPIO.input(switch)==1:
         if down == 0:
            start = time.time()
         now = time.time() - start
         m,s = divmod(now,60)
         h,m = divmod(m,60)
         msg= "%02d:%02d:%02d" % (h,m,s)
         psec = str(now-int(now))
         pstr = psec[1:5]
         msg = msg + str(pstr)
         pygame.draw.rect(windowSurfaceObj,greyColor,Rect(0,0,width,height))
         down = 1
         down = 0
      for event in pygame.event.get():
         if event.type == QUIT:
            pygame.quit()
            sys.exit()
except KeyboardInterrupt:
  print ("  Quit")
  GPIO.cleanup()
Posted: Sat Aug 10, 2019 5:19 pm
by neilgl
Ah yes I meant click on the red Select all in my post and then copy it. Then you can paste it when you have the editor (nano) open on the pi.
Posted: Sat Aug 10, 2019 6:16 pm
by hkpatnaik
Hi neilgl,
Thanks for u r patience and i made some progress
line 6 def_init_(self,master=None): invalid syntax pointing to the semi colon :
this is while i was trying to run the program
sincerely
Hare P
Posted: Sat Aug 10, 2019 6:22 pm
by neilgl
Ok post the code from your pi onto a reply here, using the “Code” tags that are in the grey bar here on this forum when you reply.
Posted: Mon Aug 12, 2019 6:32 pm
by hkpatnaik
Thanks Gordon I will definitely try your program.
Hare
Posted: Mon Aug 12, 2019 8:28 pm
by neilgl
You may get an error when you try that for pygame.locals.
Posted: Mon Aug 12, 2019 8:32 pm
by hkpatnaik
# python3 and tk
class application(tk.Frame):
super()._init_(master)
self.pack()
self.hi_there=tk.Button(self)
myfont=('times',132,'bold')
self.hi_there["text"]="54 Hello World\n(me)"
self.hi_there.config(font=myfont)
self.hi_there["command"]=self.say_hi
newfont=('Helvetica',64,'bold')
self.quit=tk.Button(self,text="QUIT",fg="red",command=root.destroy)
self.quit.config(font=newfont)
def say_hi(self):
self.hi_there["text"]="54 Hello World\n(clicked)"
root=tk.Tk()
app=Application(master=rot)
app.mainloop( )
Posted: Mon Aug 12, 2019 8:43 pm
by hkpatnaik
Hi niegll
when i run big.py
i get following errors
File" .big.py" line 5 in <module>
class application( tk.frame);
File" .big.py" line 6 in application
def_init_(self ,master=None)
Name Error: name"def_init_" is not defined
Posted: Mon Aug 12, 2019 10:10 pm
by neilgl
Looks like the copy paste is not working properly - maybe some UK to non-Uk translation.
Anyway, indentation is critical in python.
Post the code you are running in between “Code” tags
Posted: Tue Aug 13, 2019 6:30 am
by markkuk
You must add a space between "def" and "__init__". "def" is a Python keyword that starts a function definition, "__init__" is the name for a class constructor function.
Posted: Tue Aug 13, 2019 3:27 pm
by hkpatnaik
Hi neilgl & Gordon,
I ran Gordon's program and it ran perfect as prescribed. I will appreciate if u & neilgl can help me in my program.
board has 3 push button switch inputs
sw1 start on/off
sw2 record speed data
sw3 record video data
3 local or global variables
tcounter
speed
when sw1 is pushed : open a data file
clear all variables
speed= 55
display speed on the HDMI screen in the center
when we get
tcounter increments by 1
when tcounter is multiples of 10 ( i.e every second) call the random number generator ( 0 to 99)
if the random number >67 increment speed by one and display speed in the center of hdmi screen EXIT 0
if the random number is between 33 and 66 decrement the speed by one and display speed and exit 0
if the random number is between 0 and 32 keep the speed same value ( no increment or decrement) exit 0
exit 0: if sw2 pushed on then store tcounter value, speed
if sw3 is pushed on then store tcounter value
if sw1 is closed stop the program, close the file
thanks
hare
Posted: Tue Aug 13, 2019 3:40 pm
by neilgl
OK what happened when you ran the program I posted?
I also have another one ( partly stolen from @gordon77 ) that starts/stops a stopwatch using switches on GPIO pins.
Posted: Tue Aug 13, 2019 5:26 pm
by hkpatnaik
hi niegll,
I ran your program but had syntax and definition errors but gordon's program ran perfect and i could see the result 00:00:00:000 displayed on the window. I changed the font size and could display 1" and 4" characters. hope u can help me with the total program i described in the previous reply.
I may soung like a 5 yr old but i am retired and continuing education at age 70. but it is hard to learn at this age. I can do it given enough time . I never learned software but i am fairly good in electronics
hare P
Posted: Tue Aug 13, 2019 9:29 pm
by neilgl
Ok you are not much older than me. So copy and paste (into nano) my first example. Let me know if it works on your pi - it does work on mine. Indentation and spaces are important in python. The three switches requirements look pretty straightforward t implement.
I can set up another pi to be like yours - what country is it?
Posted: Wed Aug 14, 2019 8:40 am
by gordon77
I've modified neilgl's code to include a stopwatch, hopefully give you some ideas.
# python3 and tk
import time
GPIO.setmode(GPIO.BCM)
switch = 17 # pin 11, switch to +3.3v
        self.pack()
        global running
        running = 0
        self.master.title('Stopwatch')
        self.hi_there["text"] = "00:00:00:00"
        self.hi_there["command"] = self.start_clock
        L1 = tk.Label(self.hi_there, text="Click on time, or toggle GPIO #17, to start / stop " , font = 30)
        L1.place(x=20, y=180)
        self.check_switches()
    def start_clock(self):
        global start,running
        start = time.time()
        if running == 0:
            running = 1
        elif running == 1:
            running = 0
        self.update_clock()
    def update_clock(self):
        if running == 1:
            h,m = divmod(m,60)
            pstr = psec[1:4]
            self.hi_there["text"] = msg
        self.after(10, self.update_clock)
    def check_switches(self):
        global switch, start, running
        if GPIO.input(switch) == 1 and running == 0:
            start = time.time()
            running = 1
            self.update_clock()
        elif GPIO.input(switch) == 1 and running == 1:
            running = 0
        self.after(100, self.check_switches)
root = tk.Tk()
app.mainloop()
