MaverickMEL
Trying Ubuntu install - no HDMI Output
Fri Aug 02, 2019 8:53 pm
Hi all,
I just got my RBP4 (4GB). I used Etcher on my MacOS to flash Ubuntu 18.04.iso on a 400GB and 32 GB SD Card (FAT32). However the RBP doesn't give ANY video output on my Samsung flat (using a micro HDMI-HDMI adapter). Only if I do the same with flashing Raspbian it works fine.
I can't edit the config file to set HDMI to force, as I do not have access to the SD card on my Mac once the iso file is flashed.
How can I get Ubuntu correctly installed so that the HDMI port works. Unfortunately I can't use any other flatscreen for the upcoming future and as said it works fine with Raspbian.
At the moment that RBP4 is quiet useless
Any ideas?
Thanks guys
Andyroo
Re: Trying Ubuntu install - no HDMI Output
Fri Aug 02, 2019 9:21 pm
You could load Fuse and an ext driver on the Mac or purchase https://www.paragon-software.com/home/extfs-mac/
Simplest way may be boot up Raspbian and pop the Ubuntu card in an SD to USB adapter and mount it to make the edits...
davidcoton
Fri Aug 02, 2019 9:29 pm
I'm not aware whether Ubuntu supports the Pi4B (I think not), but in any case an .iso file is for x64 architecture, not ARM.
The Pi4B is not useless -- it runs the supported OS Raspbian, which, incidentally, like Ubuntu is derived from Debian.
Signature retired
Fri Aug 02, 2019 9:41 pm
Hi all,
Any ideas?
Thanks guys
Where does it state the Raspberry Pi 4B is supported ??
https://ubuntu-mate.org/download/
Raspbian Buster and OpenElec are the only officially supported Operating Systems at this present time !!
RPi 4B 4GB (SSD Boot)..
wesw82
Sun Aug 04, 2019 9:19 am
As above. Ubuntu Mate still in development for the 4B. Haven't heard anything new on this since early July. It's a case of wait and see.
