I use two hard drives
one harddisk 0.85 Amps, the other harddisk 0.55 amps
my server doesn't run both at the same time
because I've read that the usb's give a total of 1.2 amps
Is there a way to increase power
I want to run two harddisk at the same time and raid but usb power output is not enough
I am using a 3 amp offical power adapter
max_usb_current=1 setting, but the result is the same
