Java?
Posted: Fri Jul 19, 2019 4:36 am
by Carolyn28
I try to install app which need Java. Does latest Raspbian have Java?
When searching for instance "java" in Add / Remove Software, how to see only those items which has check mark in front? Or can this be done only in CLI?
Re: Java?
Posted: Fri Jul 19, 2019 5:26 am
by PhatFil
java should be installed but it may be an earlier version than your app needs??
look for openjdk..
if you need to update java for your app this may help..
https://lazyadmin.nl/home-network/raspb ... va-update/
Re: Java?
Posted: Fri Jul 19, 2019 5:40 am
by fruitoftheloom
"Raspbian Buster with desktop and recommended software" includes OpenJDK11 by default.
Though you can install in Raspbian Buster Lite:
sudo apt update
sudo apt install openjdk-11-jdk
https://packages.debian.org/buster/openjdk-11-jdk
