Tb40
(HELP ME) Broken IO pin
Fri Jul 19, 2019 1:46 am
So pin #2 or the 5v pin on my board snapped will it still work or do I have to replace it thanks in advance.
pcmanbob
Re: (HELP ME) Broken IO pin
Fri Jul 19, 2019 9:12 am
HI.
So I assume you are talking about the pin on the gpio header, as long as your pi still boots then you can keep using it,
this assumes there is no damage to the PCB, if you want to use the actual pin to connect to then you are probably going to need to replace it.
may be post a picture so we can see how its broken / damage
drgeoff
Fri Jul 19, 2019 12:12 pm
Pin 4 is directly connected to pin 2. If the board is still working you can use pin 4 for any purpose that needed pin 2.
Andyroo
Fri Jul 19, 2019 1:04 pm
A great site for pin details (both of the Pi and boards) is https://pinout.xyz/
gkaiseril
Fri Jul 19, 2019 1:17 pm
There duplicate pins for both the 5vdc and the 3vdc source and 4 ground pins. You can also use the command line program pinout to see the pin configuration.
f u cn rd ths, u cn gt a gd jb n cmptr prgrmmng.
Tb40
Sat Jul 20, 2019 1:54 am
HI.
Thank you and everyone else who replied to this post it was very helpful sorry if it was a stupid question im new to this ; )
alphanumeric
Sat Jul 20, 2019 10:13 am
This is a nice reference for the GPIO pins. https://pinout.xyz/#
And you can get the pins used by hats here, a fair number of them anyway, https://pinout.xyz/boards#
