Using feh over ssh connection
Posted: Sun Jul 14, 2019 12:49 pm
by papallot
I am trying to open a picture in my raspberry pi 3b+ from my computer (I have linux mint installed).
It is very basic:
-I connect to the raspberry:
ssh pi@192.168.1.61
-I introduce my password
-Once I am in the raspberry, I execute feh:
feh /home/pi/mypicture.jpg
the following error apperars: "feh ERROR: Can't open X display. It *is* running, yeah?"
Doing some readying, I can solve it by typing on the command line
export DISPLAY=:0
After this, it works perfectly.
Is there a possibility to do that automatically? I have tried to put it in the autostart file but it doesn't work
Thanks a lot
Re: Using feh over ssh connection
Posted: Sun Jul 14, 2019 1:40 pm
by scruss
If you do
ssh -X pi@192.168.1.61
it should set up DISPLAY correctly
Posted: Sun Jul 14, 2019 3:09 pm
by papallot
Thanks for the answer.
I have tried with that, but it still doesn't work.
After logging in to my raspi as ssh -X 192.168.1.61, if I write "printenv", I see that currently the variable "DISPLAY" is set to "localhost:10"
When I run feh, nothing happens on the screen and the terminal is stuck. I can carry on with ctrl+z.
Thanks!
Posted: Sun Jul 14, 2019 3:51 pm
by rpdom
Are you trying to get the image to display on the monitor connected on the Pi, not on the PC you're using for ssh?
ssh -X makes the Local display the one to output to.
To get it to display on the Pi you'll need to set the DISPLAY variable once logged in.
Posted: Sun Jul 14, 2019 4:55 pm
by papallot
Yes, that is correct. I am displaying the images on a screen connected to the pi with hdmi.
How can I change the variable automatically?
Thanks a lot
Posted: Sun Jul 14, 2019 6:01 pm
by scruss
Untried - and possibly in the wrong config file - but add the following near the end of your ~/.bashrc file:
if [ -n "$SSH_CLIENT" ] || [ -n "$SSH_TTY" ]; then
	if [ -n "$DISPLAY" ]; then
		export DISPLAY=:0
	fi
fi
This should set the display to use the Raspberry Pi's monitor over ssh, but still respect a remote ssh -X request if you do ever want to display things locally.
Posted: Sun Jul 14, 2019 7:55 pm
by papallot
Awesome, that kind of worked!!
I had to remove the inner if because, I don't know why, the condition [ -n "$DISPLAY" ]; it goes false.
	export DISPLAY=:0
fi
I tried that and everything works perfectly. Thanks a lot!!
If you don't mind, I would like to ask another related question:
I need to make the call from another raspberry and I am doing it inside another python script:
import sys
import subprocess
subprocess.call("ssh pi@192.168.1.61 feh /home/pi/mypicture.jpg",shell=True)
Apparently it doesn't work, the same error appears. I have done some debugging and the file ~/.bashrc is not being run.
thanks again
Posted: Mon Jul 15, 2019 12:58 pm
by klricks
Have you tried using the DISPLAY=:0 directly from ssh prompt?
DISPLAY=:0 feh /home/pi/mypicture.jpg
