Controlling the Pi with Android via Bluetooth
Posted: Sat Jul 13, 2019 9:22 am
by Ekscentricitet
I am trying to find a way to connect to my Raspberry Pi 3 B+ to my Android phone and control it from there. I managed to do that with SSH, but this doesn't suit my needs. So now I am trying to establish a connection that does not require the use of internet. My question is if there is a way to control the Pi using bluetooth (in a way similar to the SSH connection - connect and use)?
Re: Controlling the Pi with Android via Bluetooth
Posted: Sat Jul 13, 2019 10:44 am
by B.Goode
Blue Dot?
https://bluedot.readthedocs.io/en/latest/
Posted: Sat Jul 13, 2019 10:51 am
by Gavinmc42
Here is one way - Episode 6
https://ultibo.org/make/
Many other ways to run a webserver on a Pi3 and control it with anything that has network access.
Does the new Buster release upgrade the 3B+ WiFi/BT chip to 5.0 as well?
BT5.0 has some interesting interface options.
Posted: Sat Jul 13, 2019 10:58 am
by Ekscentricitet
Blue Dot?
Thanks for the answer! This won't work for me. I need to access the bash.
Posted: Sat Jul 13, 2019 11:05 am
by B.Goode
Attempting to run SSH over IP over Bluetooth sounds possible but beyond my experience.
But you don't need 'the internet' to make an SSH connection between an Android device and your RPi running Raspbian. Just a local WiFi connection. And if you don't have an accessible WiFi hotspot to connect the 2 devices, you could implement your own on the RPi.
https://www.raspberrypi.org/documentati ... s-point.md
Posted: Sat Jul 13, 2019 11:09 am
by Ekscentricitet
Thanks, I will try that.
Posted: Sat Jul 13, 2019 12:17 pm
by Douglas6
You can use rfcomm and getty to create a terminal over a Bluetooth Serial link. See here: https://www.raspberrypi.org/forums/view ... 25#p955425
